01-21-2019 06:52 AM
I know that by doing the following:
void example(int *a) { #pragma HLS INTERFACE m_axi depth=50 port=a #pragma HLS INTERFACE s_axilite port=a bundle=control #pragma HLS INTERFACE s_axilite port=return bundle=control
int A[50];
for (int i=0; i<50; i++)
A[i] = a[i]; }
I can assign an address to the register "a" located in the AXI Lite interface and my IP automatically knows the address to read the data from.
What I would like to do is something like this:
void example(int *a, int64_t addr_a, int64_t addr_b, int64_t addr_c) { #pragma HLS INTERFACE m_axi depth=150 port=a #pragma HLS INTERFACE s_axilite port=addr_a bundle=control #pragma HLS INTERFACE s_axilite port=addr_b bundle=control #pragma HLS INTERFACE s_axilite port=addr_c bundle=control #pragma HLS INTERFACE s_axilite port=return bundle=control int A[50], B[50], C[50]; a = addr_a; for (int i=0; i<50; i++) A[i] = a[i]; a = addr_b; for (int i=0; i<50; i++) B[i] = a[i]; a = addr_c; for (int i=0; i<50; i++) C[i] = a[i]; }
Thus, with a single AXI4 master interface I could read from 3 different addresses (of course this code does not synthesize). Is it possible to do something like this? And how could I test it in my testbench?
01-23-2019 04:26 AM
Hi @ieronym,
Can you try to have multiple memory arguments which are connected to single Master interface using bundle as below?
void example(int *a, int *b, int *c) { #pragma HLS INTERFACE m_axi depth=150 port=a bundle=gmem0
#pragma HLS INTERFACE m_axi depth=150 port=b bundle=gmem0
#pragma HLS INTERFACE m_axi depth=150 port=c bundle=gmem1 #pragma HLS INTERFACE s_axilite port=return bundle=control int A[50], B[50], C[50]; for (int i=0; i<50; i++) A[i] = a[i]; for (int i=0; i<50; i++) B[i] = b[i]; for (int i=0; i<50; i++) C[i] = c[i]; }
If you are using same bundle value for multiple arguments, it is going to create single AXI4 Master interface.
-Heera
01-22-2019 12:25 PM
Hey @ieronym
I think that code does not synthesize because of the assignment of int64_t to int*. But also, it's not how I would recommend reading from various addresses. The m_axi INTERFACE directive has an offset parameter, which you can set to 'direct' to tell HLS to create an axilite interface to control the address offset.
I would recommend instead creating IP which only has one s_axilite input, then passing three different address into that top level IP.
Here's the top level function I would use:
void example(volatile int *a, int addr_a[50]){ #pragma HLS INTERFACE m_axi depth=50 port=a offset=direct #pragma HLS INTERFACE s_axilite port=addr_a bundle=control #pragma HLS INTERFACE s_axilite port=return bundle=control int i; for(i=0; i < 50; i++){ a[i] = addr_a[i]; } }
And in the testbench, call that function 3 times:
int A_in1[50], A_in2[100], A[150]; //Create data for(i=0; i < 50; i++) A_in1[i] = i; for(i=0; i < 100; i++) A_in2[i] = i+50; // call the function three times with different offsets example(A,A_in1); example(&A[50],A_in2); example(&A[100],&A_in2[50]);
I think this accomplishes what you're looking for, and it should pass C/RTL Co-Sim. However, I think the waveform is confusing. You won't see the address offset change how you expect. Instead, the co-simulation just loads up the appropriate values from the testbench and leaves the address offset alone.
01-23-2019 03:14 AM - edited 01-23-2019 04:07 AM
This example has the same effect as if in my initial example I had called the example function 3 times. This means that, every time, my accelerator does the same thing and I just have to start/wait for it to stop 3 times. Also the "direct" directive has the same result as the "slave" directive except that it creates an additional port and not a register inside the AXI Lite to control the address.
In my case, my accelerator needs to read from 3 different addresses data of different sizes every time it executes (actually it needs to read 2 arrays of different size and a file). This could easily be done with 3 AXI master interfaces but I think this results to redundant utilization, and it could be convenient if the addresses where stored in 3 registers inside the AXI Lite and the accelerator could choose one of the 3 whenever it likes.
For now I think one solution could be to store the data in 3 addresses relative to the address the axi master reads from, but this makes the software developement less agile. I mean, I could just simply call mmap or malloc 3 times and pass 3 addresses to the accelerator, but now I have to do one big malloc, insert the data in a specific way and pass an address and 3 offsets to it.
PS You I right, I should have written a = (int *) addr_a; but this does not synthesize also.
01-23-2019 04:26 AM
Hi @ieronym,
-Heera
01-23-2019 05:04 AM
You are right. Thank you
