dtheodor
Read the address of an AXI4 transaction in HLS
I have connected a DMA module to the PS using the ACP port. I have an HLS IP that needs the address of each ACP transaction, please the figure below:
The blue module is my HLS IP with parameters m_axi transaction, axi_s data. What I would like to ask is whether it is possible to read the address of each transaction between the ACP port and the memory AXI interconnect. I have looked into the available methods of the m_axi variable, but I didn't find something.
Thanks!
dtheodor
muzaffer
it might get a little bit involved but it's certainly possible to code an axi monitor in hls to do this. Basically you just make a block which has awvalid, awready and awaddr as inputs (yes all inputs). This should give you enough information on what addresses are being written into.
dtheodor
Hello muzaffer,
Thanks for the quick reply.
So, what you suggest is to introduce an AXI Performance monitor module, read the awvalid, awready and awaddr signals, and provide them as inputs to my HLS IP, as shown below:
 Is that more or less what you suggest?
dtheodor
muzaffer
not really. I don't think you need the axi-performance monitor ip at all. Just make the HLS IP into something similar to it so that you can connect the ACP bundle directly to it.
dtheodor
Oh, I think I got it. You mean directly create the 3 inputs to my HLS IP, and read them from the ACP port:
Thanks a lot! I will try it and update the thread status.
