hilelpolak
Resource utilization modification
In the attached project the HLS is using a-lot of LUTs and DSPs.  Due to the total-project lack of LUTs, I want to configure the HLS to use memory block (BRAM and LUTRAM ) for this implementation.
I tried to update the directive section but it didn't help. Please assist with examples to reduce the LUT and DSP usage.
I don't have a hard latency constrains so it might the way to solve it
wenchen
Hi @hilelpolak
I took a look at your code. This function contains too many mathematical calculations. These operation needs to use LUT and DSP in which case the BRAM cannot make it.
Wen
**~ Got a minute? Answer our Vitis HLS survey here! ~**
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
