01-10-2016 12:35 AM
Run C simulation and C synthesis is OK. But when I run C/RTL co-simulation encountered with the following errors.
Generating cosim.tv.exe
In file included from apatb_wavelet.cpp:18:0:
D:/Xilinx/Vivado_HLS/2015.4/include/ap_stream.h:70:2: warning: #warning AP_STREAM macros are deprecated. Please use hls::stream<> from "hls_stream.h" instead. [-Wcpp]
In file included from D:/Xilinx/Vivado_HLS/2015.4/include/floating_point_v7_0_bitacc_cmodel.h:143:0,
from D:/Xilinx/Vivado_HLS/2015.4/include/hls_half.h:40,
from apatb_wavelet.cpp:20:
D:/Xilinx/Vivado_HLS/2015.4/include/gmp.h:62:0: warning: "__GMP_LIBGMP_DLL" redefined [enabled by default]
D:/Xilinx/Vivado_HLS/2015.4/include/floating_point_v7_0_bitacc_cmodel.h:135:0: note: this is the location of the previous definition
obj/apatb_wavelet.o: In function `wavelet':
D:\Test\wavelet\solution3\sim\wrapc/apatb_wavelet.cpp:697: undefined reference to `AESL_ORIG_DUT_wavelet'
obj/main.c_pre.c.tb.o: In function `main':
D:/Test/wavelet/solution3/sim/wrapc/apcc_db/main.c_pre.c.tb.c:567: undefined reference to `wavelet(double*, double*, int*)'
collect2: ld returned 1 exit status
make: *** [cosim.tv.exe] Error 1
@E [SIM-317] C++ compile error.
@E [SIM-321] EXE file generate failed.
@E [SIM-331] Aborting co-simulation: C simulation failed, compilation errors.
@E [SIM-4] *** C/RTL co-simulation finished: FAIL ***
command 'ap_source' returned error code
while executing
"source D:/Test/wavelet/solution3/cosim.tcl"
invoked from within
"hls::main D:/Test/wavelet/solution3/cosim.tcl"
("uplevel" body line 1)
invoked from within
"uplevel 1 hls::main {*}$args"
(procedure "hls_proc" line 5)
invoked from within
"hls_proc $argv"
Anyone know how to fix it? Please help me! Thanks!
I've attached the protject files.
01-14-2016 08:18 PM
Thanks for your suggestion.
Maybe I found where is the problem. I have installed MinGW compiler and the file of MinGW compiler automatically added into "Includes" .When I recovery my computer to the status before install MinGW compiler, then the C/RTL co-simulation passed.
01-14-2016 05:55 PM - edited 01-14-2016 05:56 PM
hi @feng86
your script / project includes the file main.c as source file for the files to synthesize; however it is your TB.
could that be the issue?
i tested your source files as-is with 2015.3 (not .4 yet .. i have a small harddrive ... ) the same cosim issue doesn't happen but it seems it gets stuck.
i cannot do more than that at the moment; EDIT : maybe you could try tp start the project from fresh as well?
Also i think you should put the "source" directory outside the VHLS project diretory in case it is reset or deleted
01-14-2016 08:18 PM
10-31-2017 07:29 PM
