bdiouiska
Run C Synthesis
Hello I am trying to do Synthesis to my algorithm but when it finishes the latency bar is fulled with "?"
I want to correct it so it gives numbers instead of "?"
Here below my algorithm
#include <stdio.h>
#include <stdlib.h>
#include <time.h>
#include <math.h>
#include <string.h>
#include <iostream>
using namespace std;
void demarche (float W[100][100],float W1[100][100],float X[100],float Sd[100],int n1,int n2,int n3){
	    float l,nu,e,Somme;
    float E[100],Y[100],E1[100],Y1[100],Deltaj[100],Deltak[100],es[100],Wa[100][100],Wa1[100][100];
    int t;
       nu=0.6;
        t=0;
        Somme=0;
	 do
    	t+=1;
        for (int j=0;j<n2;j++)
            	 for (int h=0;h<n1;h++)
                         E[j] += (X[h]*W[h][j]);
                Y[j]=1/(1+(exp(-E[j])));
        for (int k=0;k<n3;k++)
            	for (int h=0;h<n2;h++)
                         E1[k] += (Y[h]*W1[h][k]);
                Y1[k]=1/(1+(exp(-E1[k])));
                es[k]=Y1[k];
        } // Calcul du Sc
        e=0;
        for (int k=0;k<n3;k++)	{
            e+=(es[k]-Sd[k])*(es[k]-Sd[k])*0.5;
        } // calcul d'erreur quadratique
        	Somme=0;
            for (int i=0;i<n1;i++)
            	for (int h=0 ; h<n3;h++)
                 Somme += es[h]*W1[j][h];
                Deltaj[j]=Y[j]*(1-Y[j])*Somme;
                Wa[i][j]=W[i][j]+nu*Deltaj[j]*X[i];
        } // calcul des nouveaux poids Wa
                Deltak[k]=Y1[k]*(1-Y1[k])*(Sd[k]-Y1[k]);
                Wa1[j][k]=W1[j][k]+nu*Deltaj[j]*Y1[k];
        } // calcul des nouveaux poids Wa1
                W[i][j]=Wa[i][j];
        } // Changement des poids W
                W1[j][k]=Wa1[j][k];
		// Changement des poids W1
    cout<<e<<endl;
    } while ((e>0.001)&&(t<200));
void calcul (float W[100][100],float W1[100][100],int n1 , int n2 ,int n3){
	    for (int i=0;i<n1;i++){
        for (int j=0;j<n2;j++){
            W[i][j]= (float)rand() / (float)RAND_MAX;
    } // calcul des poids du couche cachée
    for (int i=0;i<n2;i++){
        for (int j=0;j<n3;j++){
            W1[i][j]= (float)rand() / (float)RAND_MAX;
int main()
    float X[100],W[100][100],W1[100][100],Sd[100];
    int n1,n2,n3;
   /* std::cout<<"donnez n1 : "<<endl;
    std::cin >> n1;
    std::cout<<"donnez n2 : "<<endl;
    std::cin >> n2;
    std::cout<<"donnez n3 : "<<endl;
    std::cin >> n3;
        cout<<"inserez la valeur "<<i+1<<" dans X "<<endl;
        cin >> X[i];
    } // Calcul des entrées
    for (int i=0;i<n3;i++){
        cout<<"inserez la valeur "<<i+1<<" dans Sd "<<endl;
        cin >> Sd[i];
*/ n1=4;
        n2=3;
        n3=2;
        X[0]=5;
        X[1]=2;
        X[2]=0.2;
        X[3]=12;
        Sd[0]=0.2;
        Sd[1]=0.02;
    // Calcul des sorties desirées
 // calcul des poids du couche sortie
 calcul(W,W1,n1,n2,n3);
 demarche (W,W1,X,Sd,n1,n2,n3);
    return 0;
Thanks for responding
calibra
Cosim: simulate the VHDL/Verilog with the C testbench.
You can also include
#pragma HLS LOOP_TRIPCOUNT min=10 max=20 avg=15
For every for loop without fixed interations.
== If this was helpful, please feel free to give Kudos, and close if it answers your question ==
calibra
The while loop does not have a fixed number of iterations at compile time.
Latency cannot be known without simulation.
Do a cosim and you will know the latency for your example.
bdiouiska
I changed the do loop to a for loop with 100 iterations, Unfortenantly it doesn't work
cosim ?? I am sorry what's that ?
calibra
