Diwen
Set axi master address through instruction set
Greetings,
I am still quite new to HLS and I still not sure how to use HLS in correct way. So, suppose I want to create custom IP that can be controlled through custom instruction set. For example, my instruction set will have width of 128-bit with the offset as following:
bit 31-0 : DDR addr 1
bit 63-32 : DDR addr 2
bit 95-64 : DDR addr 3
bit 127-96 : parameter A
How should I write my top level function? What I have tried for now is something like this:
void Top_Level(DataA_t* dataA, DataB_t* dataB, DataC_t* dataC, ap_uint<128>* instruction, int num_Of_Instruction)
	// DataA_t* dataA is axi master port for dataA
	// DataB_t* dataB is axi master port for dataB
	// DataC_t* dataC is axi master port for dataC
	// Instruction_t* instruction is axi master port for instructions
	// int num_Of_Instruction is axi lite port for specifying total number of instruction that will be given to
	/* Burst Read the instruction from DDR and store in BRAM */
	ap_uint<128> bramInstruction[MAX];
	for (int i = 0; i < num_Of_Instruction; i++) {
		bramInstruction[i] = instruction[i];
	/* Main loop that execute all of the instructions */
	ap_uint<128> temp;
		temp = bramInstruction[i];
		// Code to decode instruction
		dataA = (DataA_t*)temp.range(31,0);
		dataB = (DataA_t*)temp.range(63,32);
		dataC = (DataA_t*)temp.range(95,64);
		int parameterA = (DataA_t*)temp.range(127,96);
		// Code to pass parameter from instruction to my custom IP
		CustomIP(dataA, dataB, dataC, parameterA);
The code above is actually simplification of what I actually made. The code works nicely in csim, but it failed to synthesis will following errors:
It says that "Call parameter type does not match function signature!". What does it exactly mean?  I suspect that the reason is because I am doing pointer casting as you can see from my code? If that is really the case, then how do you pass the axi master address in instruction form?
Diwen
It seems the cause of error is indeed because of pointer typecasting. I have tried another approach where I create the struct data type for Instruction_t to become like this:
struct Instruction_t {
	DataA_t* aAddr;
	DataB_t* bAddr;
	DataC_t* cAddr;
	int parameters;
and so my toplevel become like this:
void Top_Level(DataA_t* dataA, DataB_t* dataB, DataC_t* dataC, Instruction_t* instruction, int num_Of_Instruction)
	Instruction_t bramInstruction[MAX];
	Instruction_t temp;
		dataA = temp.aAddr;
		dataB = temp.bAddr;
		dataC = temp.cAddr;
		int parameterA = temp.parameters;
Unfortunately, this also cause another error. It cannot be synthesized, according to vitis HLS this is because my struct contains pointer type.
Is there any other approach so I can avoid pointer type casting for passing the address?
