khaled_jerbi
Setting maximum phisical memory for VIVADO HLS
Hi all,
I am using VIVADO to generate a hardware code from a C description of MPEG4 Parser (long an complex code).
When the inernal physical memory reaches 499MB the compilation stops.
As it is an eclipse derived poject, is it possible to set an Xmx value of 1GO fo example before launching the tool?
thank you in advance
