Shared BRAM between different TOP functions
Can I have a shared BRAM variable between 2 TOP functions?
For example, I have 2 TOP functions
int gloabl_mem[1000];
void vadd (int a*, int b*)
        int local_vadd[1000];          // BRAM
void vmul (int a*, int b*)
       int local_vmul[1000];         //BRAM
The 2 var local_vadd and local_vmul are local to their TOP function and are implemented in the BRAM but the gloabl_mem var is in the DRAM. Is there any way to have shared BRAM between 2 TOP functions for Eg:
int shared_mem[100];
        int x = shared_mem[0];
       int b = shared_mem[0];
@kaustubhmhatre
Based on the size, HLS will automatically infer a BlockRAM. You can force it if needed using directives.
Below, is a simple example which uses ROM as the shared memory. I have forced it to use BlockRAM
int shared_mem[128] = {
  1,2,3,4,5,6,7,8,
  8,7,6,5,4,3,2,1,
  1,2,3,4,5,6,7,8,
  8,7,6,5,4,3,2,1,
  1,2,3,4,5,6,7,8,
  8,7,6,5,4,3,2,1,
  1,2,3,4,5,6,7,8,
  8,7,6,5,4,3,2,1,
  1,2,3,4,5,6,7,8,
  8,7,6,5,4,3,2,1,
  1,2,3,4,5,6,7,8,
  8,7,6,5,4,3,2,1,
  1,2,3,4,5,6,7,8,
  8,7,6,5,4,3,2,1,
  1,2,3,4,5,6,7,8,
  8,7,6,5,4,3,2,1
void vadd (int *a, int *b, int addr)
  int x = shared_mem[addr];
  for(int i=0;i<1000;i++)
    local_vadd[i] = a[i];
    b[i] = x + local_vadd[i];
void vmul (int *a, int *b,int addr)
    local_vmul[i] = a[i];
    b[i] = x * local_vmul[i];
void top(int *a, int *b,int addr)
#pragma HLS RESOURCE variable=shared_mem core=RAM_2P_BRAM
#pragma HLS INTERFACE m_axi depth=1024 port=a
#pragma HLS INTERFACE m_axi depth=1024 port=b
int temp[1000];
vadd(a,temp,addr);
vmul(temp,b,addr);
Advisor
Advisor
@kaustubhmhatre Unless something has changed very recently, the answer is simply "you can't have two top functions". HLS builds a module corresponding to the top function selected, not a group of top functions.
If you need multiple functions with shared RAM, the solution is to either merge them into a single top function with a switch that tells it which operation to perform (no shared RAM needed), or two entirely separate HLS blocks both communicating with an external BRAM.
@u4223374    Yes, having two top functions is not possible. I went with the assumption that he want's to use a shared array across two different functions within the top function
Nithin
