Martinwz
Some questions about error directives used
Recently,I was developing a FPGA project using vivado hls v2019.02. I had some questions about directives used in vivado hls. There is an example below.
If there was an array g_6[3]={1,2,3} in function "func_1", I used two directives "set_directive_array_reshape -type complete "func_1" g_6 " and  "set_directive_array_partition -type complete "func_1" g_6 " to optimize c design code. However, Vivado HLS reported error "cannot partition array 'g_6' : variable is not an array" ,“Pre-synthesis failed” and stopped synthesis process. So, are there any tool options to let vivado hls ignore those unnecessary or error directives automatically?
Best wishes!
kimon
'Hi Martin, You shouldn't apply both directives at the same time. They're essentially mutually exclusive. This should be obvious when partitioning an array completely since this essentially converts it into an set of registers that can all be accessed in one cycle. Thus, this can then not be reshaped. The same is valid in the opposite case, which is what you have.
