[SystemC] AXI bus master timing
I'm writing AXI bus master protocol as I'd like to access SoC RAM on Zybo board. However I'm not quite sure how to understend the interface of AXI4M_bus_port - the read methods seems to 'immediately' return values (there is no valid field exposed) while write buffers don't seem to be busy as well. Does those methods automatically wait or am I missing something?
Re: [SystemC] AXI bus master timing
Looking at the generated VHDL and timings - I need to create a FIFO between those two if I want to use AXI4M_bus_port which can stall on writes.
@mpiechotka your description is not very clear. What do you mean by "the read methods seems to 'immediately' return values (there is no valid field exposed)"? On its face, this behavior doesn't describe axi functionality. There should be valid field on the axi read channel.
If you are talking about your SystemC description, you shouldn't need any of these. Both read and writes should be blocking and the underlying behavior of the generated RTL should enforce the valid/ready signals and at systemC level you just observe that the read/write took some finite time to execute very similar to how processors execute your code.
@muzaffer "On its face, this behavior doesn't describe axi functionality" - yes, that was source of my confusion as at least FIFO (which has similar problem) exposes nonblocking read/write.
So in order to write multiple values concurrently without waiting for confirmation (or pipeline multiple reads) from slave I need to have multiple CTHREADs - is that correct?
@muzaffer Also is access to port synchronized accross threads or do I need to synchronize it as well (I presume you can issue a second read/write in following clock cycle).
@mpiechotka I don't have any experience with systemC usage under HLS. I write all my axi master code in C++. Normally you don't need anything complicated to get pipelined accesses. If you generate a read/write of bursts, it gets converted to axi transactions properly. I am not sure if HLS supports any form of threading. I don't think C++ synthesis supports multiple-accesses to the same maxi port but I don't know if SC supports that concept.
@muzaffer - SystemC is much closer to VHDL/Verilog in many aspects as far as I understand so I don't think answers from 'standard' C++ works...
@mpiechotka in that case you have to understand that there is no way to synthesize cthreads to RTL. you have to forward all the requests to a single axi master and let it generate the actual transactions there. It's highly unlikely that cthreads in systemc are synthesizable through HLS.
PLEASE IGNORE THIS RESPONSE
@muzaffer "in that case you have to understand that there is no way to synthesize cthreads to RTL" - what do you mean? SystemC is one of the languages supported by the HLS.
