SystemC sc_fifo and hierarchy
I have a SC_MODULE (A) which includes a sc_fifo (written in a SC_CTHREAD and read in another SC_CTHREAD).
This SC_MODULE (A) synthesizes correctly, but when I instantiate it in another SC_MODULE (B), I get an error :
ERROR: [SYNCHK 200-91] Port 'x.x.Val' (x:43) of function 'x' cannot be set to a FIFO
ERROR: [SYNCHK 200-91] as it has both write (x.cpp:29:13) and read (x.cpp:104:22) operations.
Anyone knows if hierarchy is supported in vivado HLS with SystemC designs ?
Mathieu
check this document . It may help you
https://www.xilinx.com/Attachment/SystemCVerif_ApNote_4.pdf
Thanks and Regards
Balkrishan
Thanks interesting document for mixed languages simulation in modelsim.
But in fact, my errors occurred during Vivado HLS systemc synthesis.
SystemC compilation with g++ and execution worked well.
Mathieu
 Hello sir,
     I got the same error in my design when using sc_fifo, did you solved it?  if yes, please do help me.
