04-16-2019 09:24 AM
Are there more TCL commands than the one listed with the help command in the CLI? I would like to list all of the candidate locations for directives/pragmas?
$ vivado_hls -i vivado_hls> help vivado_hls> help ALL TCL COMMANDS: add_files - Add file(s) to the current project close_project - Close the project that is currently open close_solution - Close a solution config_array_partition - Config the array partition config_bind - Config the options for micro-architecture binding config_compile - Config the optimization config_core - Config scheduling core options config_dataflow - Config the dataflow pipeline config_export - Config export options config_interface - Config command for io mode config_rtl - Config the options for RTL generation config_schedule - Config scheduler options config_sdx - Config SDx options config_unroll - Config the loop unrolling cosim_design - Simulate the RTL using C test bench create_clock - Set up a virtual clock csim_design - Simulate C csynth_design - Synthesize the design delete_project - Delete a project delete_solution - Delete a solution from the current project export_design - Package design get_clock_period - Get the clock period get_clock_uncertainty - Get the clock uncertainty get_files - Get file(s) in the current project get_part - Get the target part get_top - Get the top-level model help - Print the manpage of a command import_into_sdx - Import TCL settings into current solution list_core - List core(s) in the resource library list_part - List supported parts open_project - Open an existing project or create a new project open_solution - Open an existing solution or create a new solution set_clock_uncertainty - Set the clock uncertainty set_directive_allocation - Directive ALLOCATION set_directive_array_map - Directive ARRAY_MAP set_directive_array_partition - Directive ARRAY_PARTITION set_directive_array_reshape - Directive ARRAY_RESHAPE set_directive_clock - Directive CLOCK set_directive_data_pack - Directive DATA_PACK set_directive_dataflow - Directive DATAFLOW set_directive_dependence - Directive DEPENDENCE set_directive_expression_balance - Directive EXPRESSION_BALANCE set_directive_function_instantiate - Directive FUNCTION_INSTANTIATE set_directive_inline - Directive INLINE set_directive_interface - Directive INTERFACE set_directive_latency - Directive LATENCY set_directive_loop_flatten - Directive LOOP_FLATTEN set_directive_loop_merge - Directive LOOP_MERGE set_directive_loop_tripcount - Directive LOOP_TRIPCOUNT set_directive_occurrence - Directive OCCURRENCE set_directive_pipeline - Directive PIPELINE set_directive_protocol - Directive PROTOCOL set_directive_reset - Directive RESET set_directive_resource - Directive RESOURCE set_directive_stream - Directive STREAM set_directive_top - Directive TOP set_directive_unroll - Directive UNROLL set_part - Set the target part set_top
04-18-2019 10:36 AM
Hey @gdg ,
That's all of the TCL commands. There is no command to list the candidate locations for directives.
04-18-2019 10:36 AM
Hey @gdg ,
