11-29-2020 02:28 AM
I'm using Vitis 2020.2 on Ubuntu 18.04.4 and when i try to launch vivado using terminal the follow error appears:
wrong # args: should be "source ?-encoding name? filename".
How can i fix it?
Below i attached an image of the error.
11-29-2020 06:38 AM
Hi @Davix,
Instead of invoking Vivado from bin folder Can you try invoking from an external directory ? From external directory, source settings64.sh then invoke Vivado. For ex:-
source /tools/Xilinx/Vivado/2020.2/settings64.sh
vivado
~Chinmay
11-29-2020 06:38 AM
Hi @Davix,
vivado
~Chinmay
11-30-2020 02:32 AM
When i installed Vitis 2020.2 there was no file settings64.sh so i manually updated the environment variable (PATH) but only for the bin folders of Vitis and not for Vivado. Now i uninstalled Vitis 2020.2 and installed Vitis 2020.1 which contains the settings64.sh file and now i don't have any problems in compiling and linkin kernels. Hence i think the problem was that the environment variables for Vivado were unset.
Thanks for your help.
