11-05-2020 11:18 AM - edited 11-05-2020 11:23 AM
Background:
The Vitis Vision Libraries are an accelerated library of OpenCV and Vision functions for implementation in the Vitis environment. These libraries provide a L1 directory which contains Vitis HLS kernels as well as example designs that highlight the kernel behavior. The example designs use OpenCV for the testbench functionality, and as such, require an existing OpenCV installation. In order to accommodate a wide variety of user environments, Xilinx no longer provides a pre-installed version of OpenCV with the Vivado/Vitis tools as of the 2020.1 release. While OpenCV is not required for Vitis implementation of the Vision libraries, it is required to run the example designs, and may be desirable to use in user testbench verification.
This post describes the process for creating a standalone Vitis HLS TCL project file and augments the information found in the Getting Started with HLS section of the Vision documentation which is located here:
https://xilinx.github.io/Vitis_Libraries/vision/2020.1/overview.html#getting-started-with-hls
Flow:
This AR describes the process to create a HLS TCL script with runs the resize example in the L1 Vision directory in Windows which utilizes a user installed OpenCV library.
To utilize the examples designs, or reference the OpenCV libraries in a user testbench, the following steps must be taken:
- Install the OpenCV tools version 3.x
- Setup the environment to reference the OpenCV installation
- Create a TCL script for Vitis HLS execution which references the OpenCV libraries
Install OpenCV:
The installation of OpenCV and setting of the environment is beyond the scope of this article. OpenCV is a open-source distribution located at the following location:
https://opencv.org/
Note: The 2020.1 Vitis Vision library was verified using version 3.3 of the OpenCV library. Any version more recent than that will work, however, version 4.x may have library function changes relative to the 3.x version, and as such may require the example design testbenches to be modified. For this reason, it is recommended that example designs be run using OpenCV version 3.x.
Important: The OpenCV libraries only provide testbench functionality, and are not required and do not affect the implementation of the Vision kernels in any way.
Environment Setup:
The environment setup requirements for the acceleration platform makefile flow are described in the L1 Kernel github page located at the following location:
https://github.com/Xilinx/Vitis_Libraries/tree/master/vision/L1
This AR describes a process outside the acceleration platform makefile flow which will use the environment settings similar to the makefile flow process for consistency.
Note: The LD_LIBRARY_PATH environment variable and OpenCV PATH information must be properly set in the User's environment for this script, and the Vitis Vision example designs, to work properly. In addition, the paths to the OpenCV include libraries and binaries must be included in the environment variables of the system. Failure to do so will result in library include errors during simulation.
An example Windows environment variable settings is shown below, and will vary for each user depending on the installation directory of the OpenCV and compiler tools.
Vitis HLS TCL Script:
A TCL script to run the L1 resize example design outside the makefile flow is provided with this AR. This script is based on the Windows environment. The script is based on the following environment settings:
- OpenCV version 3.4.11
- OpenCV include directory : C:/Data/OpenCV/build_win64/install/include
- OpenCV library directory : C:/Data/OpenCV/build_win64/install/x64/mingw/lib
- Vitis Vision Directory : C:/Data/Vitis_Libraries/Vitis_Libraries-master/vision/
To run the Vitis HLS script, perform the following actions:
- place the script in the <path>/vision/L1/example/resize directory
- open the Vitis HLS command line shell and navigate to the <path>/vision/L1/example/resize directory
- run the following command: vitis_hls -f run_hls_standalone.tcl
The TCL script file contains the following sections
set XF_PROJ_ROOT "C:/Data/Vitis_Libraries/Vitis_Libraries-master/vision" # Vitis Vision Libary include directory
set OPENCV_INCLUDE "C:/Data/OpenCV/build_win64/install/include" # OpenCV header file directory
set OPENCV_LIB "C:/Data/OpenCV/build_win64/install/x64/mingw/lib" # OpenCV compiled library directory
set PROJ_DIR "$XF_PROJ_ROOT/L1/examples/resize"
set SOURCE_DIR "$PROJ_DIR/"
set PROJ_NAME "hls_example"
set PROJ_TOP "resize_accel"
set SOLUTION_NAME "sol1"
set SOLUTION_PART "xcvu11p-flgb2104-1-e"
set SOLUTION_CLKP 5
set VISION_INC_FLAGS "-I$XF_PROJ_ROOT/L1/include -std=c++0x" # Vitis Vision Include path, and C++ 11 settings
set OPENCV_INC_FLAGS "-I$OPENCV_INCLUDE" # OpenCV include directory reference
set OPENCV_LIB_FLAGS "-L $OPENCV_LIB" # OpenCV library reference
Note: In Windows, the library references must include the version number. This example uses a OpenCV 3.4.11 installation. The precise include format will depend on the user's installation and may be different than listed below.
set OPENCV_LIB_REF "-lopencv_imgcodecs3411 -lopencv_imgproc3411 -lopencv_core3411 -lopencv_highgui3411 -lopencv_flann3411 -lopencv_features2d3411"
set OPENCV_LIB_REF "-lopencv_imgcodecs -lopencv_imgproc -lopencv_core -lopencv_highgui -lopencv_flann -lopencv_features2d"
open_project -reset $PROJ_NAME
add_files "${PROJ_DIR}/xf_resize_accel.cpp"
-cflags "${VISION_INC_FLAGS} -I${PROJ_DIR}/build
-csimflags "${VISION_INC_FLAGS} -I${PROJ_DIR}/build"
add_files "${PROJ_DIR}/xf_resize_accel.cpp" -cflags "${VISION_INC_FLAGS} -I${PROJ_DIR}/build" -csimflags "${VISION_INC_FLAGS} -I${PROJ_DIR}/build"
add_files -tb "${PROJ_DIR}/xf_resize_tb.cpp"
-cflags "${OPENCV_INC_FLAGS} ${VISION_INC_FLAGS} -I${PROJ_DIR}/build"
-csimflags "${OPENCV_INC_FLAGS} ${VISION_INC_FLAGS} -I${PROJ_DIR}/build"
${VISION_INC_FLAGS}
variable in the testbench flags versus the design file flags. This setting references the OpenCV include files. add_files -tb "${PROJ_DIR}/xf_resize_tb.cpp" -cflags "${OPENCV_INC_FLAGS} ${VISION_INC_FLAGS} -I${PROJ_DIR}/build" -csimflags "${OPENCV_INC_FLAGS} ${VISION_INC_FLAGS} -I${PROJ_DIR}/build"
set_top $PROJ_TOP # set top level file of HLS IP
open_solution -reset $SOLUTION_NAME # create the project solution
set_part $SOLUTION_PART # set the solution part
create_clock -period $SOLUTION_CLKP # set the project target clock period
-ldflags "-L ${OPENCV_LIB} ${OPENCV_LIB_REF}"
-argv "${XF_PROJ_ROOT}/data/128x128.png"
csim_design -ldflags "-L ${OPENCV_LIB} ${OPENCV_LIB_REF}" -argv "${XF_PROJ_ROOT}/data/128x128.png"
csynth_design
cosim_design -ldflags "-L ${OPENCV_LIB} ${OPENCV_LIB_REF}" -argv "${XF_PROJ_ROOT}/data/128x128.png"
The final stage of the Vitis HLS flow is the exportation of the design. There are several options for this stage which are described in the HLS User's Guide. This example exports the design for RTL and runs Vivado Synthesis to obtain accurate resource utilization and estimated timing results.export_design -flow syn -rtl verilog
11-05-2020 06:22 PM
On Ubuntu 18.04 there is a bug with COSIM with respect to gmp.h.
This file location has to be added to the flags otherwise it fails.
12-04-2020 05:11 PM - edited 12-04-2020 05:12 PM
I follow the above-mentioned steps to create the resize project in Vitis 2020.2 on Windows. But I am facing a few errors,
Makefile.rules:392: recipe for target 'csim.exe' failed
C:/Xilinx/Vitis_HLS/2020.2/tps/win64/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/6.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: cannot find -lopencv_imgcodecs3411
C:/Xilinx/Vitis_HLS/2020.2/tps/win64/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/6.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: cannot find -lopencv_imgproc3411
C:/Xilinx/Vitis_HLS/2020.2/tps/win64/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/6.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: cannot find -lopencv_core3411
C:/Xilinx/Vitis_HLS/2020.2/tps/win64/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/6.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: cannot find -lopencv_highgui3411
C:/Xilinx/Vitis_HLS/2020.2/tps/win64/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/6.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: cannot find -lopencv_flann3411
C:/Xilinx/Vitis_HLS/2020.2/tps/win64/msys64/mingw64/bin/../lib/gcc/x86_64-w64-mingw32/6.2.0/../../../../x86_64-w64-mingw32/bin/ld.exe: cannot find -lopencv_features2d3411
I have attached a few screenshots for a better understanding of the issue and the steps taken..i have also attached the tcl file.
I could not find much help online regarding the error thrown so am posting here.
Please let me know if something is still missing.
12-09-2020 08:33 AM
I think what may be missing here is the LD_LIBRARY_PATH variable which should point to the compiled libraries. I show that in the environment variables image in the previous post of mine. Can you see if that resolves this then?
Thank you,
Scott
12-14-2020 03:12 AM
Hey Scott
Firstly, thank you for your time and support.
I added the LD_LIBRARY_PATH as you suggest. But the same issue is thrown.
From what I understand the path to these -lopencv_imgcodecs3411.. are not correct. If I try to trace the path as shown in the console...I don't see these files there. There are no files with those explicit names though I am not sure with what names is it suppose to reflected. Also, I do not see any other OpenCV file mentioned.
On the other hand when I open my opencv folder bin..I see related files that might be the path actually needed.
I have attached the screenshots below. Let me know what do you think.
12-17-2020 11:04 PM
I spent a week of time configurating OpenCV to work with Vitis HLS 2020 a few weeks back then. The process was frustrating but I finally made it with the help of this guide.
My guess is that you have encountered some problems with your OpenCV build. When I built it with CMAKE, the directory to the .bin folder is D:\opencv-4.2.0_mingw\opencv-4.2.0\build\install\x64\mingw\bin. From your images, the install folder is missing. I guess you may have built OpenCV with customized directory, or the build process simply went wrong. On the other hand, upon successful build, the .bin folder should include around 15 .dll files, including those that you are now missing (if you did not uncheck any package during the build). The image below shows what my .bin folder looks like for OpenCV 4.2.0. I did not check or uncheck anything during the build.
Note: I think you are using Visual Studio to build OpenCV. I did the same thing at the beginning. The build was successful but it does not work well with Vitis HLS (since they use different compilers). You may want to build it with MinGW. I followed the guild in this website to build OpenCV 4.2.0 with MinGW. It should also work with OpenCV 3.4.11.
01-04-2021 02:32 AM
Hey Jeff
This was really helpful. Thank you!!
I wanted to reply you long back but am guessing due to winter holidays or some reason the reply tab was inactive!
