embedded
Advisor
Advisor
Using Xilinx IP cores - FIR for exp. - inside HLS design
Hi all,
I am going to design a correlation IP in HLS. I was wondering whether it is possible to instantiate a Xilinx IP core - like FIR - my HLS design?
I mean part of design is C/C++ and inside it I use an FIR core from Xilinx!.
Hossein
dsakjl
Hi @embedded ,
a similar question was already discussed in the past:
https://forums.xilinx.com/t5/High-Level-Synthesis-HLS/Primitives-in-HLS/m-p/1171933
Probably you should use the FIR as external IP and implement the proper interface in HLS IP.
Regards.
