enricodeiana
Using clock signal in Vivado HLS
Hello!
I'd like to use the clock signal in my IP design but I didn't find how to do that on the Vivado HLS guide or tutorial.
I am designing a very simple IP that simulates a generic sensor. It simply outputs some 32 bit data (embedded in the core into an array) through its AXI4-Stream 32 bit output port.
Since I want to control the time interval between two output data I was thinking to use the clock signal in order to output a datum every 10 or 100 or whatever clock cycles.
But I cannot find a way to use the default clock signal that, I believe, is present in every Vivado HLS IP design.
Does anybody know how to do that?
Thank you,
Enrico
enricodeiana
the post http://forums.xilinx.com/t5/High-Level-Synthesis-HLS/How-to-create-two-clocks-one-for-ctrl-signal-other-one-for-data/td-p/440128 isn't really what I was looking for.
Anyway, it seems that there is no way to have access to the clock signal in Vivado HLS if you're writing your IP in C or C++, but you can if you use systemC.
Enrico
vijayak
Check if this helps.
Thanks,Vijay
debrajr
@enricodeiana Do you still have any questions on this topic. If not, then please close the topic as Solved and mark the post which helped you as an "Accepted Solution".
Debraj
enricodeiana
Enrico
