VHLS GUI does not start in Ubuntu 14.10 x64
Vivado HLS GUI quit during start
Here is stdout:
Vivado(TM) HLS - High-Level Synthesis from C, C++ and SystemC Version 2014.4 Build 1071461 on Tue Nov 18 16:42:57 PM 2014 Copyright (C) 2014 Xilinx Inc. All rights reserved. ================================================================
@I [LIC-101] Checked out feature [VIVADO_HLS] @I [HLS-10] Running '/opt/Xilinx/Vivado_HLS/2014.4/bin/unwrapped/lnx64.o/vivado_hls' for user 'root' on host 'ubuntu' (Linux_x86_64 version 3.16.0-29-generic) on Mon Feb 09 00:43:36 MSK 2015 in directory '/home/gash/Xilinx_Vivado_SDK_Lin_2014.4_1119_1'
@I [HLS-10] Bringing up Vivado HLS GUI ...
@I [LIC-101] Checked in feature [VIVADO_HLS]
Error log attached.
Vivado and SDK do work.
Vivado HLS work with -i option
If start GUI - quit silently.
What tested:
- Start with -n option
- Download installation and check md5
- Reinstall all
- Copy some jar from java installation (one of the posts advise)
Nothing hlps yet
Re: VHLS GUI does not start in Ubuntu 14.10 x64
Can you please try with the supported Ubuntu Linux 14.04 LTS (64-bit) version?
Thanks,Vijay
Forgot attach error log above  - here it is
Are you able to invoke Vivado HLS in CLI mode?
Try this command: vivado_hls -i
Vinay
Thanks,Vijay
@oleg.gashnikov Have you tried installing the tool on any other OS? What is the tool version being used? Is the Java version updated to the latest one?
Debraj
I have tried it with right version of Ubuntu and now it works!
Thank you!
