VIVADO HLS Error Message: math function 'tanhf' is not supported for synthesis
  I need to include 'tanhf' function in my program codes to run an application. In Vivado HLS, its showing Error message and Synthesizability check failed. How to get rid-off ? Any help will be appreciated.
for(i=0;i<ROWS_P;i++)
        temp=1;
        for(j=0;j<ROWS_P;j++)
            if(j!=i && h[j][0]==h[i][0])
                temp=temp * tanhf(LLR[j]/2);   // tanhf FUNCTION.
try tanf
check supported functions here
https://www.xilinx.com/products/design-tools/vivado/integration/esl-design.html
Thanks and Regards
Balkrishan
tanf - ok But its showing incorrect result. So tanh is must to implement my application. Any other solution.
check page 50
https://www.xilinx.com/publications/archives/xcell/Xcell79.pdf
Thanks and Regards
Balkrishan
tanhf wont support in Vivado HLS
Advisor
Advisor
The only other solution is to implement tanhf yourself. Depending on the accuracy and performance required, this can range from "extremely easy" to "extremely difficult".
