jimmystone
Virtual function in C++ Error
Hi, All
I got an errro when I usd virtual function in HLS
ERROR: [SYNCHK 200-41] test.cpp:18: unsupported pointer reinterpretation from type 'AA' to type '%class.A.4.9.15 = type { i32 (...)**, %struct.ap_uint.3.8.13...' on variable 'aa'.
My code as below
class A {
    public:
        dat_t reg;
        A(dat_t x){
            reg = x;
        virtual dat_t inv(){return 0;};
class AA: public A {
    public:
        dat_t reg;
        AA(dat_t x): A(x){
            reg = x;
        dat_t inv(){
            reg = ~reg;
            return reg;
void funC(A& a){
    a.inv();
void test (
  dat_t *y,
  dat_t x
    AA aa = AA(x);
    funC(aa);
    *y = aa.reg;
Then I found Vivado HLS supports virtual functions in ug902(2018.2). And It seem my code is OK with it.
Vivado HLS supports virtual functions (including abstract functions) for synthesis, provided that it can statically determine the function during elaboration. Vivado HLS does not support virtual functions for synthesis in the following cases:
• Virtual functions can be defined in a multilayer inheritance class hierarchy but only with a single inheritance.
What do I miss?
scampbell
One thing I will add here is that support for virtual functions has been removed in Vitis HLS. It is recommended then that code be re-written to avoid the use of virtual functions.
OK, I hope this helps,
Scott
xilinxacct
Professor
Professor
@jimmystone
If you don't need the base class virtual function (i.e. it is only there to define the interface, rather than being 'sometimes' executed... simple define that interface, and only implement in the derived class. another thought... it 'may' want to see the 'override' specifying explicitly. Both of these to help 'provide that it can statically determine the function during elaboration'
Hope that Helps
If so, Please mark as solution accepted. Kudos also welcomed.
scampbell
Scott
