Vitis HLS cannot handle "struct" with AXIS interface synthesis
Vitis HLS seems cannot synthesis "struct-array" (with code line 5~8) as AXIS interface, even it's so simple. But the normal array can be correctly synthesized (with code line 3).
I see the "Vitis HLS Migration User Guide" has some topics for this, but the official workaround seems failed too.
Any suggestion?
Hi @Oxygen_Chu
Please refer to UG1391 page28. Argument type of array of hls:: stream and the stream element has struct type, except ap_int/ ap_fixed are not supported.
struct ST {
int a;
ap_int<24> b;
void some_func(hls::stream<int> A[10], // OK. the stream element has scalar
type
hls::stream<ap_int<11> > B[10], // OK. the stream element has
ap_int type
hls::stream<ST> C[10] // Unsupported, the stream element has
struct type
//internal storage is also unsupported
hls::stream<ST> internal_storage[10]
Wen
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
yes, I see the this workaround, but why Vitis HLS makes this conceptually-simple-code so complex and user-unfriendly?
The ultimate goal of HLS technology is to make C/C++ routing changed as less as possible, and seamlessly "translate" the software-oriented language into hardware circuit if there is no conceptual conflict (malloc/free is a counter-example).
I think the software-oriented "struct-array" has no conceptual conflict with hardware circuit, since the syntax "struct" is fundamentally a "group" of elements. The elements can be handled individually and/or as-a-whole.
I tried "#pragma HLS DISAGGREGATE" to ungroup the "struct" structure into individual elements(array), and use AXIS interface synthesis for each elements(array), it failed. I tried "#pragma HLS AGGREGATE" to group the "struct" structure as a whole, and use AXIS interface synthesis for this, it failed too. So I cannot understand why this.
Is it possible to improve the AXIS interface synthesis for "struct-array" in later version?
BTW, I cannot find UG1391 page28, since UG1391(2020.1) only has 23 pages in total.
Hi @Oxygen_Chu ,
Argument type of array of hls:: stream and the stream element has struct type is not supported. Have you ever tried the pointer instead of arrays? But if there is a random access, the struct types array would not be supported. You can go back to Vivado HLS for development.
hls::stream<axiWord> &inData
I found the code above on Ug1391 v2019.2 page28. But it cannot be found anymore.  Are you using 2020.1 version of Vitis HLS?
Wen
Yes, I use the Vitis HLS for Versal.
The access is sequential as shown in figure attached.
So it doesn't make sense, what do you think?
