Vitis HLS cannot invoke DSPFP32 MADD/MACC mode for Versal
Versal's DSP58 architecture support single-precision floating-point mode with MUL/ADD/MADD/MACC, which can be directly instantiated in RTL code. But Vitis HLS seams could only infer FP32 MUL/ADD, the MADD/MACC can not be infered. Instead, the MADD/MACC is splited into a floating-point multiplier and an adder, which cost 2 DSP58 primitive.
In figure 1, the Vitis HLS doesn't support fmadd/fmacc operation, only fmul and fmadd supported for BIND_OP directive.
In figure 2, "d = a[k1] * b[k1] + c[k1]" is splited into one fmul and one fadd.
In figure 3, the final implementation utilization shows two DSP58 is used.
In figure 4, DSPFP32 truly support MADD and MACC mode.
Hello Oxygen_Chu,
Unfortunately, HLS does not support the DSP58 MAC mode in the 2020.1 release. This is planned for support in the 2020.2 release of the Vitis HLS tool.
I apologize that we don't have a better answer for that at this time, but hopefully you can continue your algorithm development until that release then.
Scott
Hello Oxygen_Chu,
Scott
Thx, boy~
