dimiter
Vitis Vision cores AXI4 Stream buggy
I'm trying to create streaming interfaces for the Vitis vision cores. Specifically I'm trying to replicate the Vitis resize IP core used on PYNQ.
The generated cores contain streaming interfaces however they cause the DMA transfer to stall on the receive side. The issue was isolated with the Vitis Vison cores.  A custom HLS core without the sidebands works.
The resize IP passes C simulation but fails on hardware. The PYNQ HLS resize example uses custom interfaces with a buggy version of Vitis vison library. Compiling that against the current version gives errors.
Attached are the modified Vitis resize HLS files and python script.
The cores were also tested with baremetal library and it fails after starting the Vitis resize IP. AXI4 lite communication proceeds correctly but streaming data stalls. DMA is configured as 32 bit word width with data width converter.
This implies that all Vitis vision at the moment cannot be used with a streaming interface unlike what the website states.
Resize_ip.c
void resize_accel(hls::stream< xf::cv::ap_axiu<24, 1, 1, 1> > &srcPtr, hls::stream< xf::cv::ap_axiu<24, 1, 1, 1> > &dstPtr, int rows_in, int cols_in,  int rows_out,  int cols_out) {
// clang-format off
    #pragma HLS INTERFACE axis port=srcPtr
    #pragma HLS INTERFACE axis port=dstPtr
    #pragma HLS INTERFACE s_axilite port=rows_in
    #pragma HLS INTERFACE s_axilite port=cols_in
    #pragma HLS INTERFACE s_axilite port=rows_out
    #pragma HLS INTERFACE s_axilite port=cols_out
    #pragma HLS INTERFACE s_axilite port=return
    // clang-format on
    xf::cv::Mat<TYPE, HEIGHT, WIDTH, NPC_T> in_mat(rows_in, cols_in);
    xf::cv::Mat<TYPE, NEWHEIGHT, NEWWIDTH, NPC_T> out_mat(rows_out, cols_out);
// clang-format off
    #pragma HLS DATAFLOW
    // clang-format on
    xf::cv::AXIvideo2xfMat<INPUT_PTR_WIDTH,TYPE,HEIGHT,WIDTH,NPC_T>(srcPtr, in_mat);
    xf::cv::resize<INTERPOLATION, TYPE, HEIGHT, WIDTH, NEWHEIGHT, NEWWIDTH, NPC_T, MAXDOWNSCALE>(in_mat, out_mat);
    xf::cv::xfMat2AXIvideo<OUTPUT_PTR_WIDTH,TYPE,NEWHEIGHT,NEWWIDTH,NPC_T>(out_mat, dstPtr);
Resize_ip test.c
#include "common/xf_headers.hpp"
#include "xf_resize_config.h"
int main(int argc, char** argv) {
    cv::Mat img, out_img, result_ocv, error;
    if (argc != 2) {
        printf("Usage : <executable> <input image> \n");
        return -1;
#if GRAY
    img.create(cv::Size(WIDTH, HEIGHT), CV_8UC1);
    out_img.create(cv::Size(NEWWIDTH, NEWHEIGHT), CV_8UC1);
    result_ocv.create(cv::Size(NEWWIDTH, NEWHEIGHT), CV_8UC1);
    error.create(cv::Size(NEWWIDTH, NEWHEIGHT), CV_8UC1);
#else
    img.create(cv::Size(WIDTH, HEIGHT), CV_8UC3);
    result_ocv.create(cv::Size(NEWWIDTH, NEWHEIGHT), CV_8UC3);
    out_img.create(cv::Size(NEWWIDTH, NEWHEIGHT), CV_8UC3);
    error.create(cv::Size(NEWWIDTH, NEWHEIGHT), CV_8UC3);
#endif
#if GRAY
    // reading in the color image
    img = cv::imread(argv[1], 0);
#else
    img = cv::imread(argv[1], 1);
#endif
    if (!img.data) {
        return -1;
    cv::imwrite("input.png", img);
    unsigned short in_width, in_height;
    unsigned short out_width, out_height;
    in_width = img.cols;
    in_height = img.rows;
    out_height = NEWHEIGHT;
    out_width = NEWWIDTH;
/*OpenCV resize function*/
#if INTERPOLATION == 0
    cv::resize(img, result_ocv, cv::Size(out_width, out_height), 0, 0, CV_INTER_NN);
#endif
#if INTERPOLATION == 1
    cv::resize(img, result_ocv, cv::Size(out_width, out_height), 0, 0, CV_INTER_LINEAR);
#endif
#if INTERPOLATION == 2
    cv::resize(img, result_ocv, cv::Size(out_width, out_height), 0, 0, CV_INTER_AREA);
#endif
    /* Call the top function */
    hls::stream< xf::cv::ap_axiu<24, 1, 1, 1> > _src;
    hls::stream< xf::cv::ap_axiu<24, 1, 1, 1> > _dst;
  // Call the top function
    static xf::cv::Mat<XF_8UC3, HEIGHT, WIDTH, NPC_T> 		imgInput(in_height, in_width);
    static xf::cv::Mat<XF_8UC3, NEWHEIGHT, NEWHEIGHT, NPC_T>  	imgOutput(out_height, out_width);
    imgInput.copyTo(img.data);
    xf::cv::xfMat2AXIvideo(imgInput, _src);
    resize_accel(_src, _dst,in_height,in_width,out_height,out_width);
    xf::cv::AXIvideo2xfMat(_dst, imgOutput);
    out_img.data = imgOutput.copyFrom();
    //resize_accel((ap_uint<INPUT_PTR_WIDTH>*)img.data, (ap_uint<OUTPUT_PTR_WIDTH>*)out_img.data, in_height, in_width, out_height, out_width);
    float err_per;
    cv::absdiff(result_ocv, out_img, error);
    xf::cv::analyzeDiff(error, 5, err_per);
    cv::imwrite("hls_out.png", out_img);
    cv::imwrite("resize_ocv.png", result_ocv);
    cv::imwrite("error.png", error);
    if (err_per > 0.0f) {
        printf("\nTest Failed\n");
       // return -1;
    return 0;
from PIL import Image
import numpy as np
from IPython.display import display
from pynq import Overlay, allocate
resize_design = Overlay("resize.bit")
dma = resize_design.axi_dma_0
resizer = resize_design.resize_accel_0
image_path = "paris.jpg"
original_image = Image.open(image_path)
original_image.load()
input_array = np.array(original_image)
old_width, old_height = original_image.size
print("Image size: {}x{} pixels.".format(old_width, old_height))
input_image = Image.fromarray(input_array)
display(input_image)
resize_factor = 2
new_width = int(old_width/resize_factor)
new_height = int(old_height/resize_factor)
in_buffer = allocate(shape=(old_height, old_width, 3), dtype=np.uint8, cacheable=True)
out_buffer = allocate(shape=(new_height, new_width, 3), dtype=np.uint8, cacheable=True)
in_buffer[:] = input_array
buf_image = Image.fromarray(in_buffer)
display(buf_image)
resizer.write(0x10, old_height)
resizer.write(0x18, old_width)
resizer.write(0x20, new_height)
resizer.write(0x28, new_width)
def run_kernel():
    dma.sendchannel.transfer(in_buffer)
    dma.recvchannel.transfer(out_buffer)
    resizer.write(0x00,0x81) # start
    dma.sendchannel.wait()
    dma.recvchannel.wait()                  ############Fails here
run_kernel()
result = Image.fromarray(out_buffer)
display(result)
print("Resized in Hardware(PL): {}x{} pixels.".format(new_width, new_height))
dimiter
Just to confirm , this issue is related to this bug
https://github.com/Xilinx/Vitis_Libraries/issues/28
To get around it one needs to use a custom datatype and /or custom converison functions.
struct axis_t {
ap_uint<8> data;
ap_int<1> last;
dimiter
I tested the same IP in AXI mode (original form from library) and it does not work either. The core passes C simulation and COSIM but fails on hardware (Ultra96)
Any idea what is wrong with the Vitis Vision L1 cores?
dimiter
Here is the procedure for anyone willing to replicate this bug:
Vivado 2020.1, Ubuntu 18.04, Vitis_hls or Vivado_hls
# STEP 1 - Install CMAKE
sudo apt-get install cmake
# STEP 2 - Install vitis vision
git clone https://github.com/Xilinx/Vitis_Libraries.git
# STEP 3 - Install OpenCv 3.4
mkdir ~/opencv_build && cd ~/opencv_build
#git clone https://github.com/opencv/opencv.git
#git clone https://github.com/opencv/opencv_contrib.git
wget -O opencv_contrib.zip https://github.com/opencv/opencv_contrib/archive/3.4.4.zip
wget -O opencv.zip https://github.com/opencv/opencv/archive/3.4.4.zip
cd ~/opencv_build/opencv
mkdir build && cd build
mkdir build
cd build
cmake -D CMAKE_BUILD_TYPE=RELEASE -D CMAKE_INSTALL_PREFIX=/usr/local -D WITH_CUDA=OFF -D INSTALL_PYTHON_EXAMPLES=ON -D OPENCV_EXTRA_MODULES_PATH=~/opencv_contrib/modules -D OPENCV_ENABLE_NONFREE=ON -D BUILD_EXAMPLES=ON ..
make -j4
sudo make install
sudo ldconfig
pkg-config --modversion opencv
ls /usr/local/python/cv2/python-3.6
cd /usr/local/python/cv2/python-3.6
sudo mv cv2.cpython-36m-x86_64-linux-gnu.so cv2.so
#STEP 4 - Modify threshold IP with streaming interface
Copy threshold folder to a folder called threshold_strm
Use attached zip file and change user with you user name on  run.tcl file with :
#source settings.tcl
set PROJ "threshold.prj"
set SOLN "sol1"
set XF_PROJ_ROOT "/home/user/Documents/Vitis_Libraries/vision/"
set OPENCV_INCLUDE "/usr/local/include/opencv2"
set OPENCV_LIB "/usr/local/lib"
set XPART "xczu9eg-ffvb1156-2-i"
set CSIM "1"
set CSYNTH "1"
set COSIM "0"
set VIVADO_SYN "0"
set VIVADO_IMPL "0"
STEP #5 - Test IP CSIM and COSIM
vivado_hsl -f script.tcl
STEP #6  Generate core
Modify width and height dimensions:
/* set the height and width */
#define HEIGHT 640
#define WIDTH 480
generate core again by issuing :
STEP #6 Use Generated IP to build DMA loopback test with threshold IP in the middle.
Fails here one the DMA receive side.  This was tested with both Vitis SDK and pynq.
The core was generated with both Vitis_hls and Vivado_hls.
On Ubuntu , to pass cosim one has to add the gmp file to the include path..
dimiter
struct axis_t {
ap_uint<8> data;
ap_int<1> last;
