lmaxeniro
Vitis library project--can I customize them by import to Vitis or Vitis_HLS?
Hi I download the Vitis library and I am able to make it run (or compiling ) follow up the guidance under the command line.
However, I am now trying to import some project to Vitis IDE or Vitis_HLS IDE, by which I can better use them. But I did not find the way to do it:
1. It can not be imported to Vitis (or HLS) IDE directly?
2. I try to make a new project in IDE and copy some source code to it, but it does not work.
Please let me know if there are any guidance document on that, or any tips?
Thanks a lot.
lmaxeniro
It seems I can make the project under the command line(make run VIVADO_SYN=1 VIVADO_IMPL=1) if everything goes well, finally I can open the project in vitis_hls.
then in vitis_hls I can export RTL design to a xo file.
