tsillanp
Vivado HLS 2017.3 not starting only splash screen visible
Any ideas. Splash screen is shown, nothing else after that. If running administrator then it runs. 2017.2 worked fine. Windows 7.
Where's the logs?
xromka
I have the same problem. After several experiments, I found that the problem occurs when running java for eclipse - in the parameter"-data C:/Users/<user_name>/.vivado_hls/2017.3/.autopilot_workspace0".
I found solutions - after deleting all old data from folder C:/Users/<user_name>/.vivado_hls/  the GUI of Vivado_HLS now runing without problem.
Good luck, Roman.
Roman.
xromka
Good luck, Roman.
Roman.
tsillanp
Thanks! This worked perfectly.
alexkarnaukhov
Deleting old data helped me first time, but now I have this problem again and deleting user data doesn`t help. Problem still exists.
UPD. Solved. I have init.tcl file with string "set_param general.maxThreads 8" to make Vivado using 8 threads by default. But, as I see, this script is incompatible with HLS... The question is where I should put startup commands, such only Vivado will use it.
seum2
Hi. Can you pls clarify which file I should delete specificly? I mean which files are the user data
mik3l3_hdl
go to C:\Users\<username>\.vivado_hls\[vivado version folder]
and within this folder delete al the folders named ".autopilotConfiguration#" and ".autopilot_workspace#" where # is a proressive number .
