Vivado HLS 2018.3 release notes?
The following document has practically no information on Vivado HLS 2018.3 changes:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug973-vivado-release-notes-install-license.pdf
Is there a different document about Vivado HLS 2018.3 changes?
Teacher xilinxacct
Re: Vivado HLS 2018.3 release notes?
@ifutritski
That is the right document.... Take a look in the "what's new" and the "IP" sections.
e.g. Release Notes 2018.3 What’s New Vivado® 2018.3 introduces new production device support. Vivado 2018.3 also has additional ease of use improvements to ensure you can increase your overall efficiency and get your products to market faster. The following devices and features are also updated in this release ....
Hope that helps
Please mark as solution accepted. Kudos also welcomed. :-)
I do not see anything about HLS changes in this doc.
Can a Xilinx employee comment?
Teacher xilinxacct
@ifutritski
I didn't look at all the notes... but I do see this in relation to HLS in the IP section...
All HLS Video Processing cores are now license free and come installed with
Vivado (VPSS, Video Mixer, Video TPG, Frame Buffer WR/RD, Gamma LUT,
Demosaic, VTC).
Too bad....read it.
This:
Demosaic, VTC).
has nothing to do with Vivado HLS 2018.3 changes!
@ifutritski,
The answer graciously provided by @xilinxacct is absolutely correct. That is the correct document for Vivado HLS release notes, and those HLS Video Processing cores are now license free, specifically as of Vivado HLS 2018.3.
Another good place to look for changes to Vivado HLS is in the Revision History of UG902. Some of those are clerical changes to the document, and others reflect enhancements to the tool.
I will add, changes to Vivado HLS might also appear in the SDAccel Development Environment Release Notes, UG1238. A notable change for 2018.3 is the "SDAccel bottom up flow".
Nicholas Moellers
Xilinx Worldwide Technical Support
