kenneth0416
Vivado HLS Simulate C++ Project
I just started learning Vivado HLS software. I am curretingly using its 2017.4 version.
Can Vivado HLs simulate and synthesize C++ files ?
I see "Run C Simulation", "Run C Synthesis", and "Run C/RTL Cosimulation"
Can those tools work with C++ file?
Do they just treat C++ files as C ?
If I need to do some tricks to use C++ files, could you guide me directions ?
hemangd
Hi @kenneth0416,
Yes you can use cpp files.
For more info. on it you can try the tutorials of HLS from here https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug871-vivado-high-level-synthesis-tutorial.pdf
And user guide UG 902 https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug902-vivado-high-level-synthesis.pdf
hemangd
hemangd
Hi @kenneth0416,
hemangd
amritarana143
How can I use python (.py) files in Vivado HLS to create an overlay?
u4223374
Advisor
Advisor
You can't. HLS does C, C++, and SystemC. For Python you will need to investigate alternative tools.
