Vivado_HLS - Window data buffers
It seems that Window data buffers (in Video Library) are not pass by reference. That means whatever I write to it in a function is not accessible by outside the function.
Has anyone come across this before?
I don't think that's correct but I'm not sure of your description.
Do you have an example testcase that can be used to show this in context?
- Hervé
SIGNATURE:
* New Dedicated Vivado HLS forums* http://forums.xilinx.com/t5/High-Level-Synthesis-HLS/bd-p/hls
* Readme/Guidance* http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369
* Please mark the Answer as "Accept as solution" if information provided is helpful.
* Give Kudos to a post which you think is helpful and reply oriented.
In the attached file,
example 1 correctly returns the value of 1 in array B. while in example 0 returns 0 in array B. This is strange since the Window class is basically an array being passed.
Thanks for the extract.
so in your code:
//Example0
subfunction0(Window<3,128,unsigned int> filterK, Window<1,128,unsigned int> outputL) {
you pass it by copy... Okay, so why don't you pass them by reference :
subfunction0(Window<3,128,unsigned int> &filterK, Window<1,128,unsigned int> &outputL) {
This should solve your issue.
- Hervé
SIGNATURE:
