stzog
Vivado HLS and cl kernel support
Hi to all!
Does Vivado HLS support IP creation from cl kernels?Is there any specific procedure?
Is C synthesis supported?
Thanks in advance.
scampbell
Hello stzog,
The HLS tools currently support C/C++ languages for kernel synthesis. Unfortunately, the HLS tools do not support OpenCL directly. However, the Vitis tools do support this language for the creation of kernels. A detailed description of this flow can be found on page (158) of the Vitis Application Acceleration Guide located here:
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2020_1/ug1393-vitis-application-acceleration.pdf
OK, I hope this helps,
Scott
stzog
@scampbell
Thanks for your reply!
It sounds strange but i managed to create OCL kernel in Vitis_HLS as IP.
The code i used was from the Vitis_accel examples and OCL kernels....Did i miss something???
stzog
@scampbell
Any more feedback my friend?
