Visitor double.j
Vivado HLS c++ csynth_design error
I get this error:
@E [HLS-70] Harris.cpp: In function 'void Harris(ap_uint<24> (*)[256], ap_uint<24> (*)[256][256], bool)':
Harris.cpp:4: error: no matching function for call to 'aesl_keep_name_class::aesl_keep_name_class_ap_uint_output<24>::aesl_keep_name_ap_uint_output(ap_uint<24> [256][256])'
Harris.cpp:33: note: candidates are: static void aesl_keep_name_class::aesl_keep_name_class_ap_uint_output<_AP_W>::aesl_keep_name_ap_uint_output(ap_uint<24>*) [with int _AP_W = 24]
Compilation of the preprocessed source 'Harris.g' failed
while executing
"csynth_design"
 and all I know is that there is something wrong with the interface for that function.
What is wrong and how do I fix it?
Or where can I find the basic rules to avoid this?
Re: Vivado HLS c++ csynth_design error
Can you post your C code here? It would be much helpful to figure out the problems.
Visitor double.j
I have fixed it now. I was changing the interface because the program did not know wich of the variables was the output. I was probably confused with pointers and references so I made some mistake.
Now It has a two array interface:
void Harris(ap_uint<24> input[MAX_HEIGHT][MAX_WIDTH],ap_uint<24> output[MAX_HEIGHT][MAX_WIDTH])
and the testbench goes like this:
ap_uint<24> (*input)[MAX_WIDTH] = new (ap_uint<24>[MAX_HEIGHT][MAX_WIDTH]);
ap_uint<24> (*output)[MAX_WIDTH] = new (ap_uint<24>[MAX_HEIGHT][MAX_WIDTH]);
//generating input
Harris(input,output);
