Vivado HLS does Not run, Black Command Screen is seen
I installed the Xilinx ISE as Vivado, DocNav , Vivado HLS and System Generator.
After the installation, I runned the Vivado HLS but show an error : libSecurity.dll does not exist on your computer.
I copied 'libSecurity.dll'  to C:XLINX/vivado_HLS/2013.2/bin and then it is solved.
But now, I click the Vivado HLS and then a black command screen is seen for a moment.So it is not open.
Please help me, my Laboratory  date is closing....
Thank you much,
Tugay
Probably. I would suggest wait for one more day and get 2013.3 and try again.
Hi Tugay,
Try out this:
1. Which OS are you using?
2. Check your java version and increase the java memory.
3. Open Vivado HLS Command Prompt and run the command: vivado_hls -verbose
Paste the output here to investigate the issue.
Hi vuppala,
1.My OS is Windows 7 Home Premium.
2.I have checked my Java version and updated to last version and increased the java memory by 1GB.
3.I click Vivado HLS, then, a Command screen appears and immediately disappears.So it not open.
4.I opened Command Screen by written 'cmd' in start. I write the 'vivado_hls' and shows an error:
" not recognized as an internal and external command, operable program or batch file "
Thanks a lot,
Tugay
For command line tools to run, you have to source the relevant script ie setup32.cmd.
3. Open "Vivado HLS Command Prompt" instead of "cmd" from Windows Start.
brucey
I tried to Vivado HLS Command Prompt as written vivado_hls -verbose.  A system error : "msys-intl-8.dll" missing.
I attach Command Prompt screen.
Tugay
Hi,it's in msys\bin directory. You can add the directory to PATH environment.
brucey
I  looked at the msys/bin.
There is no "msys-intl-8.dll"
Shall I re-install ?
