Visitor donert
Vivado HLS does Not run, Black Command Screen is seen
I installed the Xilinx ISE as Vivado, DocNav , Vivado HLS and System Generator.
After the installation, I runned the Vivado HLS but show an error : libSecurity.dll does not exist on your computer.
I copied 'libSecurity.dll'  to C:XLINX/vivado_HLS/2013.2/bin and then it is solved.
But now, I click the Vivado HLS and then a black command screen is seen for a moment.So it is not open.
Please help me, my Laboratory  date is closing....
Thank you much,
Tugay
Teacher muzaffer
Re: Vivado HLS does Not run, Black Command Screen is seen
Probably. I would suggest wait for one more day and get 2013.3 and try again.
Hi Tugay,
Try out this:
1. Which OS are you using?
2. Check your java version and increase the java memory.
3. Open Vivado HLS Command Prompt and run the command: vivado_hls -verbose
Paste the output here to investigate the issue.
Visitor donert
Hi vuppala,
1.My OS is Windows 7 Home Premium.
2.I have checked my Java version and updated to last version and increased the java memory by 1GB.
3.I click Vivado HLS, then, a Command screen appears and immediately disappears.So it not open.
4.I opened Command Screen by written 'cmd' in start. I write the 'vivado_hls' and shows an error:
" not recognized as an internal and external command, operable program or batch file "
Thanks a lot,
Tugay
Teacher muzaffer
For command line tools to run, you have to source the relevant script ie setup32.cmd.
3. Open "Vivado HLS Command Prompt" instead of "cmd" from Windows Start.
brucey
Visitor donert
I tried to Vivado HLS Command Prompt as written vivado_hls -verbose.  A system error : "msys-intl-8.dll" missing.
I attach Command Prompt screen.
Tugay
Hi,it's in msys\bin directory. You can add the directory to PATH environment.
brucey
Visitor donert
I  looked at the msys/bin.
There is no "msys-intl-8.dll"
Shall I re-install ?
Teacher muzaffer
