eisuke.mochizuki
Vivado HLS "data_pack" vs Vitis HLS "aggregate" pragma
Hi, I face problem when translate my HLS code Vivado HLS 2020.1 to Vitis HLS 2020.2.
Specifically, I use the following struct in order to connect to "M_AXIS_S2MM_STS" port of "AXI DataMover" IP.
struct StatusWord {
ap_uint<4> tag;
ap_uint<1> interr;
ap_uint<1> decerr;
ap_uint<1> slverr;
ap_uint<1> okay;
# Vivado HLS 2020.1 with "#pragma HLS data_pack"
When synthesis in Vivado HLS 2020.1 with "#pragma HLS data_pack", bitwidth of TDATA is 8 bits. It is OK.
|mm2s_sts_in_V_TDATA | in | 8| axis | mm2s_sts_in_V | pointer |
|mm2s_sts_in_V_TVALID | in | 1| axis | mm2s_sts_in_V | pointer |
|mm2s_sts_in_V_TREADY | out | 1| axis | mm2s_sts_in_V | pointer |
# Vitis HLS 2020.2  with "#pragma HLS aggregate"
In Vitis HLS 2020.2, "#pragma HLS data_pack" does not support, I use "#pragma HLS aggregate" intead. However, bitwidth of TDATA is 40 bits. It is not OK.
|mm2s_sts_in_V_TDATA | in| 40| axis| mm2s_sts_in_V| pointer|
|mm2s_sts_in_V_TVALID | in| 1| axis| mm2s_sts_in_V| pointer|
|mm2s_sts_in_V_TREADY | out| 1| axis| mm2s_sts_in_V| pointer|
I think this problem is occured by Vitis HLS specification. Vitis HLS align each elemets to 8bit.
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2020_2/ug1399-vitis-hls.pdf#page=154
Do you have any idea to avoid this problem?
frederic
I recommend you wait for 2021.1 (coming out this month) but here is a workaround using the packed attribute for structs and bit fields.
#include <ap_int.h>
#include <hls_stream.h>
struct __attribute__((packed)) StatusWord {
  char tag : 4;
  bool interr : 1;
  bool decerr : 1;
  bool slverr : 1;
  bool okay : 1;
void MyModule(
  hls::stream<StatusWord>& mm2s_sts_in,
  hls::stream<StatusWord>& mm2s_sts_out)
#pragma HLS INTERFACE axis register_mode=both register port=mm2s_sts_out
#pragma HLS INTERFACE axis register_mode=both register port=mm2s_sts_in
  mm2s_sts_out.write(mm2s_sts_in.read());
 Then the interface is reported by 2020.2 to be like this (which is I believe what you wanted with AXI Stream and most compact representation for the data):
== Interface
* Summary:
|       RTL Ports       | Dir | Bits|  Protocol  |  Source Object |    C Type    |
|ap_clk                 |   in|    1|  ap_ctrl_hs|        MyModule|  return value|
|ap_rst_n               |   in|    1|  ap_ctrl_hs|        MyModule|  return value|
|ap_start               |   in|    1|  ap_ctrl_hs|        MyModule|  return value|
|ap_done                |  out|    1|  ap_ctrl_hs|        MyModule|  return value|
|ap_idle                |  out|    1|  ap_ctrl_hs|        MyModule|  return value|
|ap_ready               |  out|    1|  ap_ctrl_hs|        MyModule|  return value|
|mm2s_sts_in_V_TDATA    |   in|    8|        axis|   mm2s_sts_in_V|       pointer|
|mm2s_sts_out_V_TDATA   |  out|    8|        axis|  mm2s_sts_out_V|       pointer|
|mm2s_sts_out_V_TVALID  |  out|    1|        axis|  mm2s_sts_out_V|       pointer|
|mm2s_sts_out_V_TREADY  |   in|    1|        axis|  mm2s_sts_out_V|       pointer|
frederic
Add the keyword "bit" when applying the AGGREGATE pragma:
#pragma HLS AGGREGATE variable=<name_of_struct_variable> bit
eisuke.mochizuki
Hi, frederic. Thank you for your reply.
I try with "bit" pragma, but it is not well.
And in synthesis log, there is "Ignore aggregate" warning.
WARNING: [HLS 214-255] Ignore aggregate pragma/directive on AXI-Stream interface 'mm2s_sts_in'
If you know, could you tell me why aggregate pragma is ignored?
Regards.
hemangd
@eisuke.mochizuki aggregate pragma does not support with axis interface with 2020.2 Vitis HLS.
Can you please try with DISAGGREGATE PRAGMA on each element of the struct? (disaggregation of data ports)
From UG 1399:
hemangd
Don't forget to give kudos and mark it as accepted solution if your issue gets resolved.
eisuke.mochizuki
Hi, hemangd. Thank you for your reply.
I try with "DISAGGREGATE" pragma.
#pragma HLS DISAGGREGATE variable=mm2s_sts_in
#pragma HLS INTERFACE axis port=mm2s_sts_in.V.tag
#pragma HLS INTERFACE axis port=mm2s_sts_in.V.interr
#pragma HLS INTERFACE axis port=mm2s_sts_in.V.decerr
#pragma HLS INTERFACE axis port=mm2s_sts_in.V.slverr
#pragma HLS INTERFACE axis port=mm2s_sts_in.V.okay
Synthesis is succesefull, however bitwidth is still 40 bits and protocol is not axis but ap_fifo.
|mm2s_sts_in_V_dout     |   in|   40|     ap_fifo|      mm2s_sts_in_V|       pointer|
|mm2s_sts_in_V_empty_n  |   in|    1|     ap_fifo|      mm2s_sts_in_V|       pointer|
|mm2s_sts_in_V_read     |  out|    1|     ap_fifo|      mm2s_sts_in_V|       pointer|
Regards.
hemangd
@eisuke.mochizuki Kindly paste your full cpp file.
hemangd
wave_rider
"data_pack" pragma can be applied to interface in vivado_hls but when "aggregate" is applied to interface in vitis_hls, it will only byte aligned instead of packed on bit level. I had raised my concern about this in this forum and NO XILINX team seems to be care.
the only work around is to do the manual packing by yourself by making everything back to ap_uint.
good luck.
eisuke.mochizuki
@hemangd This is my latest cpp file.
#include <ap_int.h>
struct StatusWord {
  ap_uint<4> tag;
  ap_uint<1> interr;
  ap_uint<1> decerr;
  ap_uint<1> slverr;
  ap_uint<1> okay;
void MyModule(
#pragma HLS DISAGGREGATE variable=mm2s_sts_out
#pragma HLS INTERFACE axis port=mm2s_sts_out.V.tag
#pragma HLS INTERFACE axis port=mm2s_sts_out.V.interr
#pragma HLS INTERFACE axis port=mm2s_sts_out.V.decerr
#pragma HLS INTERFACE axis port=mm2s_sts_out.V.slverr
#pragma HLS INTERFACE axis port=mm2s_sts_out.V.okay
And synthesis result is here.
== Interface
* Summary:
|ap_rst                 |   in|    1|  ap_ctrl_hs|        MyModule|  return value|
|mm2s_sts_out_V_din     |  out|   40|     ap_fifo|  mm2s_sts_out_V|       pointer|
|mm2s_sts_out_V_full_n  |   in|    1|     ap_fifo|  mm2s_sts_out_V|       pointer|
|mm2s_sts_out_V_write   |  out|    1|     ap_fifo|  mm2s_sts_out_V|       pointer|
eisuke.mochizuki
@wave_rider Thank you for your important information.
Yes, I think that may be best way...
ramananr
The 2021.1 release of Vitis HLS now adds support for a "-compact bit" option to the aggregate pragma. This makes the aggregate pragma (and padding removal) the same as the old DATA_PACK pragma.
ramananr
Couple of clarifications:
a. Only structs can be disaggregated using the DISAGGREGATE pragma. A stream however cannot be disaggregated.
b. Vitis HLS 2021.1 brings support for a "-compact=bit" option to the AGGREGATE pragma which will behave exactly the same as the old DATA_PACK pragma.
#pragma HLS aggregate variable=<variable> compact=bit
Vitis HLS 2021.1 will be available later this month.
frederic
#include <ap_int.h>
  char tag : 4;
  bool interr : 1;
  bool decerr : 1;
  bool slverr : 1;
  bool okay : 1;
void MyModule(
== Interface
* Summary:
eisuke.mochizuki
@ramananr Thank you for your important information.
I got it. I will try with "-compact=bit" option.
eisuke.mochizuki
@frederic Thank you for your great support.
In my enviroment, this code works good!
Yes, this is the target interface.
In Vitis HLS 2020.2, I will use this format. Thank you.
wave_rider
Thank you for finally listen to our voices
