alexafi
VivadoHLS Co-simulation Error
Hi everyone,
I am new to Vivado HLS. When I want to perform a C/RTL co-simulation with SystemC I get the following error:
In memory model top.AESL_inst_dstGrid.core_inst, during a write cycle
ERROR: Address 32570 for port '1' is outside the legal range [0..25999].
Fatal: (F1000) unknown id
In file: AESL_automem_dstGrid.h:102
In process: top.AESL_inst_dstGrid.core_inst.proc_mem @ 105 ns
@E [SIM-304] Aborting co-simulation: C simulation failed.
@E [SIM-4] *** C/RTL co-simulation finished: FAIL ***
Had anyone encountered something similar? How could I fix this issue?
I would appreciate any help.
Thank you,
Alex
ankury
which version of VHLS are you using??
Ankury
alexafi
Hi Ankury,
it's 2012.2.1
Alex
alexafi
... and I synthesise it for Zynq xc7z020clg484-1
alexafi
I also tried to simulate a much simpler design, top function is "array_axi_m". Running the program in C works fine, as well as the synthesis, but not the C/RTL co-simulation
void doit(
        volatile float *src_addr,
        volatile float *dst_addr) {
    int i;
    for (i = 0; i < SIZE; i++) {
        dst_addr[i] = src_addr[i] * 10.0 + 11.0;
void array_axi_m(
        volatile float *bus,
        volatile uintptr_t *p_srcGrid,
        volatile uintptr_t *p_dstGrid) {
    doit((float *)(bus + *p_srcGrid / 4), (float*)(bus + *p_dstGrid / 4));
With the following directives:
set_directive_interface -mode ap_bus "array_axi_m" bus
set_directive_resource -core AXI4M "array_axi_m" bus
set_directive_interface -mode ap_none "array_axi_m" p_srcGrid
set_directive_resource -core AXI4LiteS "array_axi_m" p_srcGrid
set_directive_interface -mode ap_none "array_axi_m" p_dstGrid
set_directive_resource -core AXI4LiteS "array_axi_m" p_dstGrid
And the testbench:
int main(int argc, char* argv[]) {
    float *in;
    float *out;
    float **in_p;
    float **out_p;
    int i;
    in = (float*)malloc(SIZE * sizeof(float));
    out = (float*)malloc(SIZE * sizeof(float));
    in_p = &in;
    out_p = &out;
        in[i] = (float)i;
    array_axi_m(NULL, (uintptr_t*)in_p, (uintptr_t*)out_p);
        if (out[i] != in[i] * 10. + 11.) {
            return -1;
    return 0;
And I get the error:
@I [SIM-302] Generating test vectors ...
@E [SIM-320] Generating test vectors failed.
Could please someone help me with this?
Alex
vladokr
Did you resolve your problem?
I have the same problem when runing the cosimulation.
herver
Please start a new thread explaining what you see and attach a testcase, to make it easier to reproduce.
The thread you're replying is too old, and there are a few issues in the code (!).
The OP was also using a year old tool version which may have other issues than the current version.
- Hervé
SIGNATURE:
* Vivado HLS forums* http://forums.xilinx.com/t5/High-Level-Synthesis-HLS/bd-p/hls
* Readme/Guidance* http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369
* Please mark the Answer as "Accept as solution" if information provided is helpful.
* Give Kudos to a post which you think is helpful and reply oriented.
