WHICH VIVADO ICON IS FOR HARDWARE AND WHICH ONE FOR SOFTWARE?
Two icons are seen on my desktop which one to be used for FPGA hardware design? Which one for embedded design?
Re: WHICH VIVADO ICON IS FOR HARDWARE AND WHICH ONE FOR SOFTWARE?
From your three posts, Im sorry that you seem to be having a bad day
Welcome to the world of hardware. If your a C progrmmer, its a long hill to climb.
Both Vivado and HLS are ways of making hardware.
Vivado is aimed at the HDL method of desing, VHDL , Verilog or SV
HLS, is the "High Level Synthesis " means of generating hardware, using a syntax that is C like ish.
I woudl guess fomr your other posts that your looking for amore C framework, so HLS would be your root.
There are many Xilinx tutorials and doc on this route of design
try this as a start
https://en.wikipedia.org/wiki/High-level_synthesis
https://www.xilinx.com/video/hardware/getting-started-vivado-high-level-synthesis.html
https://www.xilinx.com/support/documentation-navigation/design-hubs/dh0012-vivado-high-level-synthesis-hub.html
Just a word, HLS design is not C.
you can not take for instance a FIR design in C and drop it into an FPGA via HLS and get anywhere near the best perfoirmance.
Good luck on the journey,
try this as a start
One other thought,
are you looking at developing C code to run on a processor in an FPGA ?
if so you want the Software Developers Kit
https://www.xilinx.com/products/design-tools/embedded-software/sdk.html
Hi manoranjinimg@gmail.com
If your question is answered or your issue is solved, please kindly mark the response which helped as solution (click on "Accept as solution" button below the reply).
Thanks and Regards,
Aoife
