Wait for external signal trigger in HLS block
Hi everybody,
I have a simple dubt, my main question is about wait on external signal.
I'm implementing a startup process for 100G Ethernet peripheral, the actions to perform are explained in PG165 v2.5:
1. Write the below registers:
    0x00014 : 32'h00000001 [CONFIGURATION_RX_REG1 for ctl_rx_enable]
    0x0000C : 32'h00000010 [CONFIGURATION_TX_REG1 for ctl_tx_send_rfi]
2. Wait for RX_aligned then write the below registers:
    0x0000C : 32'h00000001 [CONFIGURATION_TX_REG1 for ctl_tx_enable to 1’b1 and
    ctl_tx_send_rfi to 1’b0]
I would implement this like:
void CMAC_Ctrl(volatile uint32_t * ptrCMACport, uint1 RX_aligned)
#pragma HLS INTERFACE s_axilite port=ptrCMACport offset=off depth=1024
// write on ptrCMACport
while(RX_aligned != 0b1){};
My question/dubt is:
Is the while construct valid to wait an external signal inside an HLS block?
Since the HLS block is executed once the ap_start is asserted how can it refresh the rx_aligned?
Please suggest me an approach, in vhdl is very simple task but since many IP are moving toward AXI control interface
I would like to understand how this situation can be managed with HLS, or if HLS is not the suitable technology.
Thank you
I think a 'while loop' which polls for a signal is valid. When synthesized, it will simply translate into a FSM where one of the states will wait on the 'RX_aligned' signal to be asserted before transitioning to another state.
