Observer ain0102
What is the meaning of latency?
Hi.
My HLS synthesis result.
Does latency affect the operating time?
Re: What is the meaning of latency?
Latency describes the number of clock cycles for proccessing the date.
With a latency of 10 the IP needs 10 clockcycles for generating the output data (IP-Start at clockcycle 0, data ready with clockcylce 9).
If the initiation intervall has the same value as the latency the IP is blocked für new data in between.
If it has a smaler value, the IP can start to process the next data while it is still processing the old.
This is mostly the case if the IP contains several subfunctions which must run in sequence.
Kind regards
Thomas
Kind regards
Thomas
