What's the difference between ap_memory and bram ?
Hello, everybody.
As ug902 said,
"The bram interface mode is functional identical to the ap_memory interface.
The only difference is how the ports are implemented when the design is used
in Vivado IP Integrator:
•An ap_memory interface is displayed as multiple and separate ports.
•A bram interface is displayed as a single grouped port which can be connected
to a Xilinx block RAM using a single point-to-point connection."
However, I synthesized my code with  a sub function of matrix multiply.
With default ap_memory interface ,  the sub function could be optimized with
different latencies using configurations  such as "... ARCH = 3 ","..UNROLL_FACTOR = 4" and so on.
However, with bram directive , I found my code are NOT optimized for latency,
it always show the fixed latency.
Re: What's the difference between ap_memory and bram ?
Hi !
I know my answer is late, but I had the same question.
from page 68 in this doc:
http://hron.fei.tuke.sk/~adam/pca/7.High-Level%20Synthesis.pdf
I quote :
"bram — The same as ap_memory, except that when bundled using IP Integrator, the ports are not shown as individual ports, but grouped together into a single port."
They are referring to the Zynq book (page 321).
The reason why you're getting different results might be the number of r/w ports to that BRAM block.
Best,
Rashed
