What's the main difference b/w use of gcc and clang in HLS ?
Hi, dear HLS elites,
 As far as I know, the Vivado HLS supports either GCC or CLANG compiler. (assume under Linux platform)
 From HLS synthesis view, what's the main difference ? Also,  from HLS C sim/Co-Sim view, what's the main difference ?
 I'd like to understand how user makes best decision on the two choices.
All the best,
Re: What's the main difference b/w use of gcc and clang in HLS ?
@nanson
Starting Vivado HLS 2018.2, you will only be able to use gcc compiler. The CLANG option has been removed.
Nupur
BTW, are there any HLS users choosing clang as the compiler ? If yes, what's your concern ?  Thanks
@nanson
Nupur
I have noticed that the option to select the clang compiler has been removed in the GUI in 2018.3 indeed. Running the tcl command with the clang option (csim_design -compiler clang) gives the following output:
INFO: [SIM 211-2] *************** CSIM start ***************
INFO: [SIM 211-4] CSIM will launch CLANG as the compiler.
So it seems as if the use of the clang compiler can still be forced with the tcl command.
To answer to the OP: I used clang because of its C++11 support (that the gcc compiler lacked).
