delphicgp
Why I can only Unroll 2 times?
Hi all,
I'm trying to optimize my HLS solution. The first step I'm tring is to unroll the loop. For example, I have the function like following:
void matpro(const float v[15],float d[15]){
char i,i111,i112;
float b_StateVectors[15];
  for (i = 0; i < 15; i++) {
    d[i]=v[i]*b_StateVectors[i];
After I unrolled the for loop, HSL showed me this result.
I think the loop is not full unrolled (the result looks like unroll by 2 and pipeline the loop). I have tried a lot of ways, but still it wasn't full unrolled. Can anyone tell me what's wrong here? I don't care the resource, I just want to get the maximal throughput (use 15 mutiplier at the same time).
Thank you in advance,
Gongpei
gszakacs
Instructor
Instructor
It's possible that your arrays are being stored in some sort of memory rather than independent registers.  If so, there would be a maximum of 2 read ports to that memory structure limiting the loop unroll factor to 2.  Here's a thread that discusses a similar issue:
http://forums.xilinx.com/t5/High-Level-Synthesis-HLS/Optimizing-for-loop/m-p/457640
-- Gabor
gszakacs
Instructor
Instructor
-- Gabor
ywu
Like gszakacs said, what you are seeing is limited by the number of memory ports for the input/output arrays. To get completely parallel logic, you will also need to completely partiaion the two arrays using ARRAY_PARTITION directive.
Cheers,
Jim
delphicgp
Thank you! You are right.
After I set all my array as complete partition, I get expected unroll result.
nehagaur
I am targeting xc7a35tcpg236   Artix device. but after the partitioning, i will not get it complete unrolling
