Why are the results of interval in synthesis report not same as that in co-simulation report
When I use Vivado HLS, I find the interval in synthesis report is not same as that in the co-simulation report.
This is the synthesis report. It shows the interval is 25.
This is the co-simulation report. It shows the interval is 0.
Attached is the source files.
Re: Why are the results of interval in synthesis report not same as that in co-simulation report
Hi @araongao2015
Please check the below link and see if that matches your use case.
https://www.xilinx.com/support/answers/60472.html
Thanks,Vijay
Hi @vijayak
I read the message from the answer record you provided.
The II=111 from C/RTL co-simulation is calculated based on ap_start intervals (that is, how often new data is sent to the HLS module).
[Araon]: Does this mean the interval is measued using different method. In synthesis report, the II is the cycle between two adjacent ap_ready, while in cosimulation report, the II is the number of cycle between ap_start and the first ap_done. is this statement right?
The Vivado HLS C/RTL co-simulation testbench does not give data immediately after the HLS module is ready to accept data.
[Araon] Does this mean the mechanism among csim, C/RTL co-sim and RTL simulation is different?
When you use the IP in your own RTL, as soon as ap_ready is asserted, you can send new data to it to achieve II=28.
[Araon] So does this mean the cosimulation results are not reliable?
