XAPP1167 HLS compilation error
I'm getting an error for 'fast-corner' example from XAPP1167
hls_video_fast.h:344: error: no matching function for call to 'FAST_t_opr(hls::Mat<1080, 1920, 16>&, hls::Mat<1080, 1920, 0>&, int&, bool&, int [16][2])'
I'm running on Windows7 x64 with ISE 14.6 and Vivado 2013.2.
It's the same as in http://forums.xilinx.com/t5/High-Level-Synthesis-HLS/Compiling-with-VIVADO-HLS-on-Ubuntu-64/td-p/337427 post, exept I'm running Windows.
Let me try to reproduce the issue. Ensure that you have followed the steps before that properly.
Debraj
