about vivado_hls error in ubuntu 10.04
I am new to vivado hls i was installing vivado_hls 2017.4 in ubuntu 16.04 version,i got the error for every program video read and write i was trying 2 projects but got the same errors.Workspace 1_044.png
and also RTL hanging error in co simulation error.
any answer will help to me.
thanks in advance
k sharmila
Scholar u4223374
Re: about vivado_hls error in ubuntu 10.04
Can you post your code?
This generally means that the C compiler can't find a main function. The main function should be in one of the testbench .c/.cpp files, and should be defined as either:
int main() { ... }
or
int main(int argc, int ** argv) { ... }
this is my code can you please clearly explain how could i run the code.
and am attatching my code below.
thanks for your reply
k sharmila
hi can anyone check the code and make it run
Scholar u4223374
This goes back to an answer I gave in one of your earlier threads: in your core.cpp file, you never actually put anything into img_out. I can't tell you what you should put into img_out, but I would imagine that it's meant to be some function of left_diff, right_diff, up_diff, and down_diff. For testing, you could just copy any of those to img_out, and see what happens.
