adding PIPELINE rewind & dataflow pragmas explode run-time
I have a design which sythesizes in less than 10 minutes (actually significantly less). I decided to add dataflow to it which gave me a "loop with multiple exits" dataflow synthesis error so I added pipeline rewind.
With these two pragmas added the design has been running for more 1.5 hrs (94 mins) now. Is there any hope that it will complete? Any suggestions on how to get more optimization in shorter time?
Tags (2)
Re: adding PIPELINE rewind & dataflow pragmas explode run-time
It's been 352 minutes of cpu time and hls is still cranking. It doesn't look like it's going to terminate. Any suggestions?
Normally that happens when it's tried to unroll a huge loop completely, which is itself a result of applying pipelining at too high a level. For example, if you code looks like this:
for (y = 0; y < 1024; y++) {
#pragma HLS PIPELINE
	for (x = 0; x < 768; x++) {
		// Do something to an image
then it'll attempt to completely unroll (all 768 iterations) of the inner loop, so it can all run in one clock cycle. What you need is this:
