after synthesizing systemC, the VHDL doesn't work as desired
Hello i am writing a SystemC Queue that is synthesizable as follows:
the cpp file:
#include "queue.h"
#include "flit.h"
 void Queue::push(flit input) {
	if (!queue_full) {
		queue_empty = false;
		queue[queue_first] = input;
		queue_first++;
		if (queue_first == SIZE) {
			queue_first = 0;
		if (queue_last == queue_first) {
			queue_full = true;
		} else {
			queue_full = false;
	} else {
#ifndef __SYNTHESIS__
		cout<<"full"<<endl;
#endif
flit Queue::pop() {
	flit output;
	if (!queue_empty) {
		queue_full = false;
		output = queue[queue_last];
		queue_last++;
		if (queue_last == SIZE) {
			queue_last = 0;
			queue_empty = true;
		} else {
	}else{
		cout<<"queue is empty. cannot pop"<<endl;
	return output;
int Queue::size(){
	return SIZE;
bool Queue::empty() {
	return queue_empty;
bool Queue::full() {
	return queue_full;
flit Queue::front() {
	flit output;
	if (!empty()) {
		flit output = queue[queue_last];
		return output;
	}else{
	assert (false);
#endif
	return output;
 the header file:
#ifndef QUEUE_H
#define QUEUE_H
#include <stdlib.h>
#include "systemc.h"
#include "flit.h"
#include "constants.h"
#define SIZE MAX_CREDITS
class Queue{
	int queue_last;
	int queue_first;
	flit queue[SIZE];
	bool queue_empty,queue_full;
public:
Queue(){
	queue_empty = true;
	queue_full = false;
	queue_last = 0;
	queue_first = 0;
void push(flit input);
flit pop();
int size();
bool empty();
bool full();
flit front();
#endif
However after synthesis i try testbenching the vhdl code provided by vivado and when i try pushing new data ( buffer.push(data) in systemC ) in the vhdl code synthesized by vivado it doesn't seem like its doing anything. Also with the data_pack directive the queue is implemented like a RAM and have signals like buffer_adress0, buffer_ce0, buffer_we0, buffer_d0 and buffer_q0. an ideas why the vhdl is not working properly? is my systemC written properly for synthesis?
there should be some ports on the top level of the ip named ap_start, ap_done, etc.
Are you setting ap_start to 1 ?
i dont see ap_start in the port section. However i have a signal grp_fu_2153_ap_start : STD_LOGIC  and even if i instantiate it to 1 nothing changes.
