ap_memory address when export to ip-catalog or edk
I have function with array argument. array size is 400. when I synthezise the report says the address is 9 bit. But when I export to ip-catalog or edk the address width shows 32 bit. Could you explain why?
Jothi
In general AXI address width is 32 please check if you have any AXI interface directives  to that addres
Vanitha.
I do not gave any axi directive on this variable. Even I have checked with the example array_Ram. Still it gives 32 bit adders even the address is other number
What is your addr data_type, can you show your code here ?
Vanitha
Address data is not assigned by me. When you assign a directive ap_memory, depends on the array size, the address width is decided.
Jothi
As synthesis shows 9 bit and only exporting makes difference I guess some interface directives were being added else it could be a tool issue.
Can you upload yoour test project for investigation ?
Vanitha.
You could check the array_ram from the example design
I am using vivado 2013.3
Can see that but that's only external (32-bit) and on the top level wrapper of the generated IP to be added as the .bd in Vivado IPI. Internally its connected only to the 9 bits of ADDR respectively for the 3 ap_memory interfaces and rest of the bits are unused.
Debraj
The packaged IP has 32-bit address bus. The actual memory depth is controlled by the MEM_SIZE (in bytes) property on the IP, which will be propagated to the BRAM connected to it in IPI.
Cheers,
Jim
