array implementation: 2014.4 vs 2015.2
Hello
I have a simple code for array calculations
as following:
void arraySum(int A[size], int B[size], int result[size])
	int sum[size];
	int mult[size];
	int diff[size];
	for(int i=0; i<size; i++)
		sum[i] = A[i]+B[i];
		diff[i] = A[i]-B[i];
		mult[i] = A[i]*B[i];
	for( int z=0; z<size; z++)
		result[z] = sum[z] + diff[z] + mult[z];
The interesting that the arrays implementation looks diifferent between HLS 2014.4 and HLS 2015.2
as following
HLS 2015.2
    * Memory:
    | Memory |    Module    | BRAM_18K| FF| LUT| Words | Bits| Banks| W*Bits*Banks|
    |sum_U   |arraySum_sum  |      256|  0|   0|  76800|   32|     1|      2457600|
    |mult_U  |arraySum_sum  |      256|  0|   0|  76800|   32|     1|      2457600|
    |diff_U  |arraySum_sum  |      256|  0|   0|  76800|   32|     1|      2457600|
    |Total   |              |      768|  0|   0| 230400|   96|     3|      7372800|
HLS 2014.4
    * Memory:
    |sum_U   |arraySum_sum  |      160|  0|   0|  76800|   32|     1|      2457600|
    |mult_U  |arraySum_sum  |      160|  0|   0|  76800|   32|     1|      2457600|
    |diff_U  |arraySum_sum  |      160|  0|   0|  76800|   32|     1|      2457600|
    |Total   |              |      480|  0|   0| 230400|   96|     3|      7372800|
So why each one has different implementation BRAM resource utilization 160 for HLS_2014.4 and 256 for HLS_2015.2??
Karim
Re: array implementation: 2014.4 vs 2015.2
Hello All & @eng_karim
I took the example code provided in the top of this thread. I run it through the 2 different VHLS versions using a kintex7 ;
After export_design -evaluate verilog the designs have both 768 BRAMs used (results below).
It looks like 2014.4 was making wrong estimations and 2015.3/2015.x are inline with Vivado.
FWIW the RTL code are nearly identical in the 2 versions.
I don't want to stir away the argument, but the line   result[z] = sum[z] + diff[z] + mult[z]; could be written   result[z] = A[z] + A[z] + A[z]*B[z];.... and not use RAMs at all.... maybe that's only what you need?
If you don't like what you get as a result then please just recode it in a way that makes more sense to you.
I'm not joking, use your C code to tell the tool exactly what you want instead instead of letting it infer a RAM for you because what VHLS does is only writing (* ram_style = "block" *)reg [DWIDTH-1:0] ram[MEM_SIZE-1:0]; with 32 and 76800. The RTL synthesis or implementation is going to make the actual BRAM logic - maybe having the the RAMs as 1 bit large and 16k long like mentioned before?
If you want something else, then just write it.
I give an example at the end of this post; minimum BRAMS, so trading lots of BRAM for lots of LUTs to make the multiplexers ; also included the export_design -evaluate report.
Implementation tool: Xilinx Vivado v.2014.4
Device target:       xc7k325tffg676-2
Report date:         Tue Sep 01 10:05:41 PDT 2015
#=== Resource usage ===
SLICE:          443
LUT:            688
FF:             231
DSP:              3
BRAM:           768
SRL:              0
#=== Final timing ===
CP required:    10.000
CP achieved:    8.611
Timing met
Implementation tool: Xilinx Vivado v.2015.3
Report date:         Tue Sep 01 10:04:55 PDT 2015
SLICE:          453
LUT:            690
FF:             231
DSP:              3
BRAM:           768
SRL:              0
CP required:    10.000
CP achieved:    8.921
Timing met
const int size = 76800;
const int bram_size = 512;
struct my_ram
    int ram_array[size/bram_size][bram_size];
    my_ram() {
#pragma HLS array_partition variable=ram_array complete dim=1
    int read(int addr) { return ram_array[addr/bram_size][addr%bram_size];}
    void write(int addr, int value) {ram_array[addr/bram_size][addr%bram_size]=value;}
void top(int A[size], int B[size], int result[size])
	my_ram sum,mult,diff;
		sum.write( i,A[i]+B[i]);
		diff.write(i,A[i]-B[i]);
		mult.write(i,A[i]*B[i]);
		result[z] = sum.read(z) + diff.read(z) + mult.read(z);
Report date:         Tue Sep 01 10:37:00 PDT 2015
SLICE:         2221
LUT:           6154
FF:             329
DSP:              3
BRAM:           450
SRL:              0
CP required:    10.000
CP achieved:    9.490
Timing met
- Hervé
SIGNATURE:
* New Dedicated Vivado HLS forums* http://forums.xilinx.com/t5/High-Level-Synthesis-HLS/bd-p/hls
* Readme/Guidance* http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369
* Please mark the Answer as "Accept as solution" if information provided is helpful.
* Give Kudos to a post which you think is helpful and reply oriented.
what is the latency for each implementation? probably the two versions are making different choices. Also are the two solutions using the same target chip?
yes both using the same chip xc7z045ffg900-2 (Zynq 706)
HLS 2014.4
+ Timing (ns):
    * Summary:
    |  Clock  | Target| Estimated| Uncertainty|
    |default  |  10.00|      8.18|        1.25|
+ Latency (clock cycles):
    * Summary:
    |     Latency     |     Interval    | Pipeline|
    |   min  |   max  |   min  |   max  |   Type  |
    |  691202|  691202|  691203|  691203|   none  |
HLS 2015.2
+ Timing (ns):
    * Summary:
    |ap_clk  |  10.00|      8.16|        1.25|
    * Summary:
actually even 160 is too much. If one builds 32 bit memories out of 18Kb BRAM at 512x36, one needs only 150 of them and a couple levels of muxes to select which one is in use.
For what it's worth, Vivado 2015.1 matches Vivado 2015.2 (256 BRAM_18K blocks each).
At a guess, to make 160 RAMs (in 2014.4) it's done sixteen 8K*2-bit RAMs in parallel to get 32-bit, and then lined up ten of those in series to produce the requested depth (76800). I'd guess that this saves logic compared to using 160 512*36-bit blocks, since for that you'd need a 160-way multiplexer to select which BRAM_18K was being used at any time.
I'm not sure how it's managed to use 256 BRAM_18Ks. I can't find any logical mapping that'd use that many.
In the produced Verilog code, the RAM turns up like this:
(DWIDTH=32, MEM_SIZE=76800)
HLS has just asked for a RAM big enough to hold everything, and its own resource usage figures seem to be a guess at how Vivado (non-HLS) will behave during its synthesis/implementation process.
I think that we start tolook how to build these arrays
but from my point of view We forgot to ask ourselves Why two versions of the same tool behave differently for translating the same piece of code ?? why such inconsistency ?
I will share the sysnthesis report for both just to have a look on them
@muzaffer @evanslatyer
I can explain the 160 for 2014.4 easily
Simply each bit is built separately from the other one
76800/(16*1024) = 4.68  BRAM18  approximately 5
then for 32-bit values it will 32*5 = 160BRAM18K
but for 2015.2
I have no idea !!!
One can do a 16 to 1 mux in a single slice so 150 to 1 mux is not too bad but I do like 8kX2 solution too. It's a matter of usage. Waste 10 18K brams or use more logic.
That seems to be how HLS works. It'll happily map a 3-bit * 2-bit multiplier (used to select an array address) into a DSP48E, even though it'll only occupy a couple of LUTs anyway. I gather that when you get to the main synthesis/implementation (in Vivado non-HLS) you can get these implemented in LUTs.
There is a roadmap to have a Core for implementing Multiplication operation in LUT's instead of DSP's in HLS itself. Stay Tuned :)
Debraj
 But No one give me an explanation for this difference in implementation between the two versions ??
SLICE:          443
LUT:            688
FF:             231
DSP:              3
BRAM:           768
SRL:              0
CP required:    10.000
CP achieved:    8.611
Timing met
SLICE:          453
LUT:            690
FF:             231
DSP:              3
BRAM:           768
SRL:              0
CP required:    10.000
CP achieved:    8.921
Timing met
struct my_ram
    my_ram() {
SLICE:         2221
LUT:           6154
FF:             329
DSP:              3
BRAM:           450
SRL:              0
CP required:    10.000
CP achieved:    9.490
Timing met
- Hervé
SIGNATURE:
Thank @herver
Actually I wrote this example just to report the difference in the implementation between the two versions
This point is not clear to me
"After export_design -evaluate verilog the designs have both 768 BRAMs used (results below).
It looks like 2014.4 was making wrong estimations and 2015.3/2015.x are inline with Vivado."
do u mean that the sysnthesis results changed after export and from which report you got that values ??
or did u  check with vivado ??
also why did u use   kintex7 ?
Let me try to explain again.
What i'm saying is that the report from the C synthesis from VHLS are only estimates.
To get better numbers is to run RTL synthesis and implementation using Vivado.
either you try yourself directly in Vivado or better, this is possible in VHLS from the export design feature.
Either use the VHLS GUI or from the TCL VHLS command line. In GUI do export design and select evaluate. On the tcl command line the equivalent command is export_design -evaluate verilog.
since both the RTL synthesis / implementation resource results in 2014.4 and 2015.x are the same, i conclude thaat the reporting results for this design is erronous in 2014.4 and is better in 2015.x
is that clearer?
- Hervé
SIGNATURE:
 I got it
Thanks for your patient  @herver
This means that I shouldn't rely anymore on the estimations
I have run it and got that values for Zynq 706
it is bit strange for me that the versions didn't give similar results
HLS 2014.4
SLICE:          517
LUT:            825
FF:             169
DSP:              3
BRAM:           768
SRL:             20
CP required:    10.000
CP achieved:    7.826
HLS 2015.2
SLICE:          446
LUT:            709
FF:             189
DSP:              3
BRAM:           768
SRL:             20
CP required:    10.000
CP achieved:    9.193
Glad we have come to a common understanding.
The difference in LUT/FF (and as a consequence slices) does not worry me too much; you can also see that the timing achieved is also different.
The input C designs is the same but 2 tools versions are used to generate RTL and they are potentially different: it may well be that the microarchitecture generated is different.
imagine that those are 2 valid solutions in the exploration space of the possible implementations of the C code in RTL that meet 10ns critical worst period.
if you cross reference with my results, they were both the very similar (also recall the FPGA used are different)
if you want to explore further this topic, you can try to run Vivado RTL synth and impl from VHLS 2014.4 generated RTL solution on Vivado 2015.2 and vice versa
- Hervé
SIGNATURE:
