mbence76
bug: print value in testbench from hls::stream
Dear Xilinx and Users,
I found a small bug in Vitis HLS  2020.2:
If the main() testbench is to print values from a stream coming from my_main(), then :
- If the last two values in the stream are the same then only 1 printf prints, the other does not.
- If either the values are different OR the printf's are different (e.g. one an extra space in the text) then it does print fine.
- If the two values are the same, and the two print lines are exactly the same, but there is some other instruction between the printing lines, then it prints fine too.
I used two identical lines:
printf("some text : %4x \n", (unsigned short)m2i.read());
However, the number of data taken out from the stream is OK.
So even the not printing line does take out the last value from the stream.
Miklos
dsakjl
Hi @mbence76 ,
I confirm you that the bug is in the console of Vitis HLS GUI, not in CLI execution.
Regards.
dsakjl
Hi @mbence76 ,
I tried your code in Vitis HLS 2020.2 but I wasn't able to trigger the bug.
Please, can you share your tb?
Regards.
mbence76
Hi @dsakjl ,  dut and tb attached.
Thank you very much for checking it out.
UPDATE:
I simplified the code and replaced the attached files.
Miklos
dsakjl
Hi @mbence76 ,
here what I got from C simulation:
"INFO: [COSIM 212-302] Starting C TB testing ...
text 3
text 3
text 3
The maximum depth reached by any of the 1 hls::stream() instances in the design is 0"
From Co-simulation:
"## quit
INFO: [Common 17-206] Exiting xsim at Wed Feb 10 14:43:33 2021...
INFO: [COSIM 212-316] Starting C post checking ...
text 3
text 3
text 3
Can you share your build options?
Regards.
mbence76
Hi @dsakjl ,
I am not sure how to extract the build options from the project.
They should be all default settings, however I made an archive zip of this demo project. I hope this helps.
I was looking at the Console window prints, not the _csim.log.   The latter seems to be OK.
Miklos
dsakjl
Hi @mbence76 ,
Regards.
