c file for FPGA
With reference to document ug871-vivado-high-level-synthesis-tutorial.pdf where I can find fir.c and related files?
Which document provides c files details from which we can generate synthesizable FPGA design?
Re: c file for FPGA
Hi manoranjinimg@gmail.com
There is a link in UG867 to the .zip containing the file or you can navigate to this webpage and scroll down to UG867 and click the 'associated files' link.
Once the zip is downloaded navigate to the following directory: ug871-design-files.zip\ug871-design-files\Introduction\lab1.
Cheers
Cheers
Re: c file for FPGA
Cheers
Cheers
Re: c file for FPGA
Do you have any update on this?
If your question is answered or your issue is solved, please kindly mark the response which helped as solution (click on "Accept as solution" button below the reply).
Thanks and Regards,
Aoife
