zdai_splunk
can't read the ip created from HLS ip package
Hi There,
I have a project that use the Vitis Library IP, more specifically, the zstd_decompress IP. I was able to compile the code into RTL and export a Vivado IP package.
Then I want to instantiate the IP in my own design. Below is a test script I used to create the IP:
# Create the HLS IP .xci file using tcl script.
set HLS_REPO_PATH repo
set HLS_IP_VLNV   xilinx.com:hls:xilZstdDecompressStream:1.0
set HLS_IP_OUTPUT ip
set HLS_INST_NAME hls_ip_inst
create_project -in_memory -part [device_part] -force
set_property ip_repo_paths $HLS_REPO_PATH [current_project]
update_ip_catalog -rebuild
set_property ip_output_repo $HLS_IP_OUTPUT [current_project]
## make HLS IP Output folder & create the HLS IP
file mkdir $HLS_IP_OUTPUT
create_ip -vlnv $HLS_IP_VLNV \
          -module_name $HLS_INST_NAME \
          -dir $HLS_IP_OUTPUT
generate_target all [get_files $HLS_INST_NAME.xci]
# synth_ip [get_ips xilZstdDecompressStream]
close_project
The ip can be created successfully without issue. However, when I tried to synth_ip or read_ip with the [get_ips] command, it always failed with this WARNING:
# read_ip [ list \
#     [file normalize ./ip/hls_ip_inst/hls_ip_inst.xci]
WARNING: [Coretcl 2-176] No IPs found
 As a result, my design can't find the IP and then failed.
Note: if I used [get_files *.xci] I was able to synthesize the IP locally, However, my own design still can't find the module:
ERROR: [Synth 8-439] module 'xilZstdDecompressStream' not found
Any idea?
Zefu
zdai_splunk
Hey Aoife,
Thanks for replying. I was able to fix the error by 'set property generate_synth_checkpoint false [getfiles inst.xci]'.
Doing this make the IP global and be recognized correctly.
thanks
Zefu
aoifem
Hi @zdai_splunk
You can take a look at the following tutorial which runs through how to successfully export IP from HLS, and a small bit of troubleshooting.
https://forums.xilinx.com/t5/Design-and-Debug-Techniques-Blog/AXI-Basics-7-Connecting-to-the-PS-using-AXI4-Lite-and-Vitis-HLS/ba-p/1137753
Can you make sure the part you selected in HLS is the same part you selected in Vivado? If there is a mismatch, then your IP won't import.
Aoife
**~ Got a minute? Answer our Vitis HLS survey here! ~**
zdai_splunk
Hey Aoife,
thanks
Zefu
