cannot find loop detail in synthesis
I created some loops in my code and add some mark, but in synthseis detail loop, I can not find the  loop which names kernel_row. Is there someting wrong in my code? 1.png2.png3.png
Advisor
Advisor
Is there a pipeline pragma somewhere? Even in the function that calls Layer_weights_load? Pipelining a section causes all sub-loops to be unrolled and all sub-functions to be inlined, which would explain why your loops have disappeared.
Hi liao_zi_lan@qq.com ,
Can you find the kernel_row in the analysis window?
Wen
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
